Dash wire harness in my 1977 corvette?
Old 08-24-2012, 01:41 PM
KcMike
KcMike's Avatar
Originally Posted by lvmyvt76
I think LL is saying his car is altered, not the harness altered. I think you have something plugged in wrong, maybe on a large connector, you are off a lug to make things operate crazy. Check all connections where there is more than wire feeding in. Sometimes things just get plugged in wrong. I have never had any problems with LL or their products.
To the OP, you say your car is not altered, nothing but stock motor and everything, no aftermarket amps or anything altered under the hood?
You are correct, LL thinks the car is altered. The harness is stock, I hope. I figured that it must be something I have plugged in funky. So, I went through every plug and wire. They all seem to be good. The connectors are almost fool proof as long as you don't bend a blade over when plugging it in.
I bought the LL harness because it was so recommended. And I am not saying that there is anything wrong with the harness, yet. It is extremely well made and I like the workmanship on the harness. But, it does not work, YET.
Old 08-24-2012, 01:44 PM
KcMike
KcMike's Avatar
Originally Posted by lowes-yellow77
hmmm, now that I`ve had my coffee and a little awake
STEP 1
try putting car in reverse or drive anything but park or neutral and see if it will crank please chock the wheels or apply brake in a open area. if it does then track from center console to steering column, the harness will be built back assward,
STEP 2
If it doesnt return to park just turn key to ON not crank, and tap starter solenoid, when it does start try to turn it off with key,If it will not you know that it wlll be between ignition switch wiring to dist, only thing to keep car running would be the 12 volts to the dist, if you have a msd box disconnect it and hook up the factory 12 volt source to dist also and try step 2 again.
STEP 3
If it still wont turn off with key on, look at old harness compared to new one where it plugs into fuse box,
they may have made harness wrong and installed wrong male plugs between IGN, ACC, OR BAT
If you have a electric choke use testlight/multimeter and see if there is power there 100% of the time, should only be power with key on,
Hope this will help a little bit,
lowe
I will give this a shot. Hope tomorrow, if not I have to go to Chicago for most of the week. Looks like good things to try and narrow it down.
Old 08-24-2012, 02:08 PM
lowes-yellow77
lowes-yellow77's Avatar
Default will check
[QUOTE=KcMike;1581654211]Interesting you mention IGN, ACC, And BAT. I have focused some time working on those plugs. Of the four plugs, the top two are hot all the time and the bottom two are only hot when I turn the key to run. Do you know if that is correct?[/QUOT
I will check on mine either today or tomorrow and let you know
lowe
Old 08-24-2012, 02:11 PM
KcMike
KcMike's Avatar
[QUOTE=lowes-yellow77;1581654440]
lowe
Thanks! Could you also let me know what color the wire is to each?
Old 08-24-2012, 10:23 PM
lowes-yellow77
Default here you go
[QUOTE=KcMike;1581654462]
kcmike,
also off the pink and black there is a tap if you want to get ignition power for something looks to be factory
Old 08-25-2012, 12:52 AM
KcMike
KcMike's Avatar
[QUOTE=lowes-yellow77;1581657881]
kcmike,
Thank you!!! This is great information. I will let you know if this leads to the solution.
Old 08-25-2012, 08:24 PM
KcMike
KcMike's Avatar
[QUOTE=KcMike;1581658653]
THANK YOU
Old 08-25-2012, 08:29 PM
KcMike
KcMike's Avatar
THANK YOU Very much for the great pic and labeling. Unfortunately the fuse block is the same on my car. I tried again and disconnected the two plugs from the ign switch (on top of the steering column) and there is still power to everything that would normalcy have power if the key was in the run position. That seems very strange to me. The power has to be coming directly to the system before the switch. I guess I am down to pulling out the harness. I am going to be really pissed if it turns out the harness is the wrong one.
Old 08-25-2012, 08:56 PM
lowes-yellow77
before you tear it apart....
quick question so if you have power windows they work with key off?
reverse lights with key off?
ok disconnect the third wire down, one that is pink and black going into fuse box car will still start but anything that is key on power shouldnt work, ie.power windows radio, gauges.
Not trying to put the blame on you but I do belive somewhere off the fuse box off the black/orange wire or the second one that has power at all times as per my car.....somehow you have tapped into a IGN power wire only from a12 volt all the time source, a wire may have a correct clip to fit but it doesnt mean it goes there.
lowe
Old 08-25-2012, 11:14 PM
KcMike
KcMike's Avatar
lowe
Lowe, you can blame me all you want. I would like nothing more than to figure out that it is a wire I put in the wrong place or it is the wiring in the car.
OK, the power windows work all the time. With or without the key on.
The reverse lights only come on when the key is in the run position.
When I disconnect the third wire (pink and black) the car will still turn over, don’t know if it would start or not as there is not enough juice in the battery right now. The rest of the electrical system seems to work better. The gauges and lights do not work unless key is in the run position. I need to do some more work on this part. Seems like we may be on to something here. It is very strange that disconnecting the wire from the space that is keyed caused the rest of the electrical system to work better. I will study the wiring layouts and get back with you.
I am leaving for Chicago for work early Sunday morning and will not be back until late in the week. This will bug me until I get back and have time to work on it more. Thank you for your help! I only wish I could play with it now. Oh well, work has to be done in order to buy part for the car.
Mike
Old 08-25-2012, 11:57 PM
lowes-yellow77
Ok, yep we all have to work to buy buy buy.
When you say lights won't work which ones are you talking about,with the pink and black disconeccted and key one nothing that is ignition should work, so we know its going to be in this circuit somewhere, I will look over some schematics and see where IGN power can cross with all the time power, and will update post if I find somewhat of a idea.
By the way electrical issues can drive people nuts I just take a easier approach than most people, know how its suppose to work then go from there by elimination.
I chased a dead short and found after a 3-4 days of chasing that the old shift light idicator from before the auto to 4 speed swap housing cracked and was rubbing power to ground it damn near drove me completly nuts. So no worries just take your time and the problem will be found.
Lowe
Old 08-26-2012, 12:39 AM
KcMike
KcMike's Avatar
Lowe
I was talking about the headlights. They only work when the key is on, not all the time like before I unplugged the 3rd wire. I went back and checked all the electrical again and it all seems to be working correctly. I was not able to spend much time with it, but it sure seems to work good with what I was able to check. I am looking forward to returning and spending next weekend with it. Thanks again for your help!
Old 09-03-2012, 01:49 PM
  #33
KcMike
KcMike's Avatar
Well I finally got back in town and had the weekend to work on the wire problem. And it is still not right. In order to get the system to work like normal I had to unplug the top wire of the two that are still plugged in to the four in the center of the fuse block. That is the orange and black wire is not unplugged from the spot that is hot all the time. The only wire of the four is the number 3 wire, the Pink and black one is still plugged into the spot that is a keyed location. With the wiring like this everything appears to be correct. The power is on when the key is in run, car runs and turns off like it should, and so on. However, when I was start thinking it is all good, it is not. But I learn something every time. When I use the power windows it blows the 10 amp fuse that is the instrument fuse. It is on the right side center of the fuse block and marked Gauges. OK, I am not electrical genius but I do know that the power windows cannot run through that 10 amp fuse. It is supposed to run through the 30amp breaker. I can pull the 30 amp breaker out and the windows still work. Something is very wrong, any guess. Am I down to it being the wire harness? What do you think?
Old 09-04-2012, 01:43 AM
  #34
lowes-yellow77
I did some looking there appears to be a early and late dash wiring harness for a 77, thats the only thing i can think of at this point and time, but yes something is not right especially if the harness is plug and play.
lowe
Old 09-04-2012, 12:19 PM
  #35
KcMike
KcMike's Avatar
lowe
I talked to someone different ay LL today and was very pleased with the conversation. He was very helpful and took the time to learn what was going on with the electrical system. We decided to replace the power window relay befor taking out the harness. He said that what it is doing, should not be happening. I agreed and laughed. May be something shorted within the fuse block also. I ordered the relay and will let you know if it helps.
Old 09-21-2012, 02:14 PM
  #36
KcMike
KcMike's Avatar
Ok, I finally received the relay and got tome to put it in the car. Unfortunately it did not fix the problem. However, I was convinced that I was on the right track based on all the testing and from the process of elimination. So I decided to start at the relay and track or pull out all three wires that plug into the power window relay. I made it only about 8" from the relay and found a wad of electrical tape on the wires. It was around all three wires. I was a little giddy about taking off the tape. And my suspension was correct. Someone that owned the car had stripped all three wires and wrapped a wire around them so that they would short out together. Why you may ask? Well, apparently because the fuse block was rusted and the power window breaker would not stay in the block they needed to get power to the window system. Because it allowed power to flow back into the entire electrical system it must have Bowen the fuse to the instruments. It is only a 10 amp fuse, so they changed it to a 30 amp fuse in the old fuse block. I fixed the wires and it is ALL good now. Thank you all for you help in tracking down the problem.
Old 09-24-2012, 01:45 AM
  #37
lowes-yellow77
Default hell yeah
well at least you will know for the future take your time and it will all come to pass. you know now that the car has been monkeyed with a little bit and will soon work out all the kinks.
lowe
Quick Reply: Dash wire harness in my 1977 corvette?
