Half shaft problem
Old Sep 1, 2012 | 09:29 PM
Indiana73's Avatar
Indiana73
Cruising
Default Half shaft problem
Tried to drive my 73 after it sitting for awhile. In gear it acted like the rear wheels were locked. Up on blocks, it seermed fine. Now there is a loud noise coming from rear end. If you look underneath at the half shafts, the right shaft appears to be separated from the rear end approx. 3/4" and the right wheel tips in when I put it back on the ground. Sounds serious. Can you provide any help?
Old Sep 1, 2012 | 10:42 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Side yoke worn out to the point the c clip fell off. Time to pull the differential and replace or rebuild it.
