77 Cruise Control Replacement
Old Sep 5, 2012 | 11:44 AM
ted13b's Avatar
ted13b
Default 77 Cruise Control Replacement
The cruise control cable is shot on my 77 and the part is NLA. I've searched and found threads from people with similar issues, and I've read that they replaced the system with a later year. What year cruise system are people using? Are they replacing just the actuator? Or the transducer, harness, etc?
Old Sep 5, 2012 | 11:47 AM
MelWff's Avatar
MelWff
Where have you been looking? The aftermarket vendors carry them.
Old Sep 5, 2012 | 12:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ted13b
...The cruise control cable is shot on my 77 and the part is NLA...
I hopped over to eBay and found both cables listed, upper and lower.
Old Sep 6, 2012 | 11:44 AM
ted13b's Avatar
ted13b
Thanks for the help guys, but it's not the speedo cable I need. I'm looking for the cable that goes from the cruise vacuum actuator up to the carb, the one that actually pulls on the throttle lever.
Old Sep 7, 2012 | 11:18 AM
lvmyvt76's Avatar
lvmyvt76
no longer made, that I could find. Need to find a corvette junk yard. One year only part. Changed my car over to a newer cruise set up, like off a 80.
Old Sep 7, 2012 | 11:33 AM
Easy Mike's Avatar
Easy Mike
You could possibly make your own servo cable. Not much to them.
To 77 Cruise Control Replacement
