best Sawzall blade for cutting trailing arm bolts?
What make and model of blade is KNOWN to work cutting the stock trailing arm bolt? What tooth count do I want?
I am going to the home despot to get blades and need to know who has had success with what?
Thank you for your help.
John
John
Try Lowes then, or your l;ocal electrical or plumbing supply house should carry them. I work for Lenox and have for 28 years now. Yes the finer tooth blade works fine. Either a 14 or 18 tooth works the best. The Lenox Gold is a little more money but will last longer than the standard Lenox blade. These are coated blades. Try to get the 9 inch and if these are a little to long which they can be grind off the end to the length needed. The 6 inch is a little short sometimes. Definitely use some type of cutting lubricant. Anything is better than dry.
Received 3,136 Likes
But I agree, the Lenox are great blades if you can find them
Mooser
Received 3,043 Likes
St. Jude Donor '05
Just buy a few they are cheap.
Any brand blade will be fine they are only like grade 5? Metal blade will cut it like butter
unless your shims are rusted together so badly that you have no choice than to cut through them also..... I went through two blades per side.
Milwaukee "The Torch". I cut a few inches off the blade to take out some flex and made it easier to get in there.
http://www.northerntool.com/shop/too...3524_200213524
