C3 Wiring diagram AM/FM-8track (FCC Data Model GM 2700)
5th Gear
Hi US corvette community and friends,
in my corvette, 1978 Indy Pace Car L48 at, there is an orig. AM/FM-8track installed. 8-track tape is working properly but AM/FM does not work. I receive in germany only the American Forces Network broadcast station in Frankfurt/Germany. I suppose that the radio needs to be modified / fixed because the car installed antenna works and I receive further AM/FM stations w/ another US radio.
To do further radio investigations, it would be very helpful to get a radio wiring diagram / manual (as a pdf file) w/ the following data I've found on the radio chassis:
Service Ref ' 81YFMT1
Part # 7898490
S/N # 1025184
I appreciate your suggestion and feedback.
Greetings from germany.
Walter
Part # 7898490
S/N # 1025184
Walter
Hi Walter
Were you able to get some diagram or manual?
I just pulled my radio fromm a '77 and have the same model GM2700
Service Ref ' 80BFMT1
Part # 7898510
S/N # 1420511
I guess if some documentation is available it will be the same.
If you have any documents, then you could make me really happy if you share it.
Regards from Hungary
Part # 7898510
S/N # 1420511
Part # 7898490
S/N # 1025184
Walter
Part # 7898490
S/N # 1025184
Walter
5th Gear
Hi,
unfortunately until know I do not have a electrical diagram for this device.
I hope maybe some vette US friends can advise in the near future. In case I'll get support, I'll keep you updated.
Kind regards from germany
5th Gear
Hi,
I really appreciate your advise.
Due to NCRS techn. book H26 on my doorplate indicates Apr. 26, 1978 so there is a good chance that 77 images can work hopefully.
BTW:
Do you as well have a "soft copy manual " for the FM/AM 8 track device available or where to download ?
Kind regards,
Walter
BTW:
Kind regards,
Walter
