Motive brake bleeder vs. this one...
I use this one, got it at another place for $2.99, it's got a magnet and I attach it to the rotor, it ain't rocket science you pump the pedal take a look for bubbles in the clear line, no more bubbles and your done
http://www.canadiantire.ca/AST/brows....jsp?locale=en
The ORIGINAL and bestest
Toronto Events Coordinator
+1 for the Motive bleeder. I've been using it for several years, and at this point could never go back to brake bleeding any other way. At first, I bought the basic kit with only the one adapter I needed for the vette. I have since bought several more adapters for my other vehicles. Quality product that works great.
I kept cringing at the cost of motive, and I absolutely hate the HF one.... so I got a air-powered vacuum pump, and used cups from the HF system to fashion a reservoir to pull through.... works like a charm....
Also, if you plan on keeping your C3, having a powered vacuum source makes your life a lot easier (it sure made mine easier).....IMO worth it. Problem with the headlights? hook up the vacuum pump to the vacuum source line at the firewall, and trace for leaks. Problem with the HVAC system? same thing, problem with vacuum leak? hook up the line and listen for hissing.... very easy to use, and not terribly expensive.
Anyone but me have good luck using Russell 'Speed Bleeders'? Price is right, for me, for something I will use maybe every 4 years. Bleeds DOT 5 in my system, without any problems.
http://www.amazon.com/1965-1982-Corv...+speed+bleeder
Yep, simple work well.
I've never had to do this in a car yet but in motorcycles when there was air trapped in the brake system i use to back bleed the system. The idea being that air wanted to float up in the lines and you couldn't pump fast enough to get the air forced down and out of the line.
I would get a large syringe from a farm store and use a short 2 inch or so piece of vinyl hose on the end of the syringe. then fill the syringe with brake fluid and purge the air from the syringe and 2 inch hose and connect to the bleeder on the wheel. Open the bleeder and force the fluid back into the resivoir. Of course you had to suck fluid out of the resivoir with a turkey baster before you started to keep from over flowing it. Always worked for the hard to get air bubbles.
