Are these stub axles salvageble?
Need help to move forward--
--still learning about the clutch packs and shims and don't know yet if that can compensate for picking up the 1/4"+ side play.
About four of the splines show a hammering effect. I measured the skinniest of the gaps between the groove and the end of the axle.
Thanks,
- Is there enough meat between the c clip groove and the end of the axle?
- Can these twisted edges be ground down and still work?
Thanks,
Not sure what you mean by "salvageable"? They look like they would be acceptable cores. I wouldn't consider using as-is with the wear you have, there's more than 1/8" missing from the ends.
A rebuilder will cut them just below the groove and add a hardened end that includes a new groove, so yours have enough left to be rebuilt.
Edit: So you have 0.104" left which means they have worn 0.080", not 1/8" like I stated above. Still too far gone to use as-is.
At least each axle holds a $30 core value.
You know how this is going to go... Once in there replace everything because having to take it out all over again is a 'big deal'.
The old saying goes: "An ounce of prevention is worth a pound of cure".
Start with rebuilt axle shafts from a reputable vendor and change out all wearables and you will be fine.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
BHK.. that metal is worn off in tiny tiny little shavings.. Usually you can feel the grease and it will feel like it has an abrasive feel to it. If someone has changed the fluid in the rear end then more than likely you'll see nothing. If you look at the yoke below you'll see you are missing the entire tapered end...
From our web site, here is a picture that shows you what is missing.
I didn't see if you have h/d or standard yokes.. but here is a link to both.. you can use the current sale coupon to save even more....
We have them new or reman... http://willcoxcorvette.com/advanced_...ds=Side%20Yoke
