TruFlex Rear Bumper Mod
Old Feb 3, 2013 | 06:22 AM
rodney25's Avatar
rodney25
Default TruFlex Rear Bumper Mod
Hi All,
I'm dry fitting a TrueFlex bumper to a 75 convertable. The two top corners are a bit off. I read in the instructions that came with the bumper that you can cut the inside area of the bumper to allow the bumper to fit better. Has anyone done this? Does anyone have any pics or docs on this? Anything would be greatly appreciated.
Old Feb 4, 2013 | 03:43 PM
gkz's Avatar
gkz
Originally Posted by rodney25
Hi All,
Mine was the same way. I glued my bumper on. Scratched off the gel coat, added epoxy/mat, ground into shape, added epoxy filler for final contour.
Other side:
Old Feb 4, 2013 | 09:00 PM
rodney25's Avatar
rodney25
Wow, Thank you so much. The exact spots you filled are the issues with my bumper. What brand materials did you use? Thank you again for replying, awesome pictures.
Old Feb 4, 2013 | 09:43 PM
mrmagrath's Avatar
mrmagrath
Epoxy? I though you had to use polyester resin on Tru Flex bumper covers? I cut mine. No big deal. I had to add about 1/2" to one corner of my front bumper cover. Rear was good. No real filling, just a bit of sanding. The more effort you put in to the fitting, the better the result. Tedious, but well worth it.
Old Feb 4, 2013 | 10:10 PM
gkz's Avatar
gkz
Epoxy: West System products (www.westmarine.com); Mat: West Systems or any mat where the label states it can be used with epoxy or Polyester resin (most autoparts stores).
Old Feb 5, 2013 | 01:10 AM
rodney25's Avatar
rodney25
I was wondering, can I use fiberglass and resin to build the bumper to match the fender?
Old Apr 22, 2013 | 12:16 PM
dlcross53's Avatar
dlcross53
2nd Gear
I too will be putting on a tru flex bumper, hopefully it will fit better. My question is how do you get the top retainer nuts on? Theres no way I'm going to get my hands between the angle iron between the gas tank and bumper. Would it be possible to cut out the angle iron with a saws all ? Or will this destroy the integrity of the frame. Am I going to have to enlist the help of the little kids in the nieborhood to put them on? Any help will be greatly appreciated!
Old Apr 22, 2013 | 03:12 PM
7t9l82's Avatar
7t9l82
cut the old one off.
Old Apr 22, 2013 | 06:01 PM
dlcross53's Avatar
dlcross53
2nd Gear
Thats what I thought. Didn't think it was adding much structure to frame. Will cut out. Will make linstallation a whole lot easier.
To TruFlex Rear Bumper Mod
