9 leaf to 7 do I need any kind of spacers - CorvetteForum - Chevrolet Corvette Forum Discussion
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette
Old 02-03-2013, 02:51 PM   #1
colliedogg
Junior Member
colliedogg's Avatar
Default 9 leaf to 7 do I need any kind of spacers
switching to a firmer spring is there a thickness difference,do I need to compensate for it.
colliedogg is offline   Reply With Quote
Old 02-03-2013, 03:35 PM   #2
Matt Gruber
CF Senior Member
on my 72 the bolts were about 1/8" too short. i used a thinner washer, but had i known, i'd of ordered the correct bolts
Matt Gruber is offline   Reply With Quote
Old 02-03-2013, 07:53 PM   #3
sfsvettes
CF Senior Member
Support Corvetteforum!
sfsvettes's Avatar
Default 9 to 7 leaf
no , you should be good....
you can use longer a bolt to adjust ride height . I have used 8-10" bolts to lower my car.
Your new spring may raise the rear of car , depending on manufacture they are arched differently sometimes.
good luck
sfsvettes is offline   Reply With Quote
Old 02-03-2013, 08:10 PM   #4
cagotzmann
CF Senior Member
cagotzmann's Avatar
Default 1978 9 leaf to 7 leaf.
In my 1978 the original 9 leaf was 2 1/2" width the 7 leaf was 2 1/4 width. 2 options. you should need a spacer or you will need to replace the diffcover with 2 1/4" spacing, replace the plate for 2 1/4" spacing as well. I made some spacers 1/8" thickness and added on both sides. You can also buy these spacers. I have since also replace the 7 leaf with a 360 LB mono spring from VBandP. the Mono spring is much better than the 7 leaf steel for me. Softer and better handling but needs to be protected from heat where the exhaust runs.
cagotzmann is offline   Reply With Quote
Old 02-03-2013, 09:48 PM   #5
gbvette62
CF Senior Member
gbvette62's Avatar
Quote:
77-79 Corvettes, with the 7 leaf spring, came with spacers placed in front of and behind the spring. This is because the Gymkhana 7 leaf spring is narrower. Other than the spacers, all of the other rear spring hardware should be the same.
The spacer plates are available from most Corvette vendors, for about $13 for the pair.
gbvette62 is offline   Reply With Quote
Old 02-03-2013, 11:13 PM   #6
mrvette
CF Senior Member
mrvette's Avatar
Get a plastic spring and get over it, why waste time???
they ride SO much better, and when combined with Bilstein shocks you are FAR better off, and lob 500 lbs off the rear of the car....
the ride is SO much better,.....handling too.....
VBP is who I got mine from years ago.....
mrvette is online now   Reply With Quote
Old 02-04-2013, 12:45 AM   #7
LT1driver
CF Senior Member
LT1driver's Avatar
plastic vs metal is personal choice..me .. wouldn't replace a metal spring with plastic to save my life so to speak, my 03 zo6 has plastic and would not put metal on it..leave it as designed is my take, but to each their own....good luck on choice to all.
LT1driver is offline   Reply With Quote
Old 02-04-2013, 01:13 AM   #8
Shark Racer
CF Senior Member
Shark Racer's Avatar
Quote:
The composite reduces weight but requires the shock damping to increase. Not a big deal. A lazy exhaust setup could get you in trouble too, if it's routed too close to the springs.
Other than that... nothing to worry about. They put composite springs on these cars in 81/82.
They would have likely been there in 63 if the technology was there.
Shark Racer is offline   Reply With Quote
Old 02-04-2013, 09:16 PM   #9
colliedogg
Junior Member
colliedogg's Avatar
right now money was the the reason for going with a metal spring and a new spring is going to much better than the old one,also the heat from the exhaust on a composite spring was a concern. I am just trying to get it road worthy so I can drive it while fixing it up,the spring is weak and the bushings almost non-existent.When I can afford it,it will get a mono spring and new TA's with all the fixin's. Better is better than best,because best almost never happens.
Old 02-04-2013, 10:09 PM   #10
Shark Racer
CF Senior Member
No such thing as "best" anyways. As you said the iron spring is cheaper, works. If you were going for the "best", a composite spring would not be the "best".
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 9 leaf to 7 do I need any kind of spacers
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Do I need any other parts to install this Callaway C6 shifter? mkiv808 C5 Tech 10 06-16-2014 09:03 PM
    Extra theft protection needed? New owner Gnickell C6 Corvette General Discussion 9 02-23-2014 08:11 PM
    If I sell a gun privately... randommj Off Topic 30 03-06-2013 04:06 AM
    Gel Coat do I need to worry about it? WilliamHall C1 & C2 Corvettes 9 06-11-2003 09:38 PM
    Cold Cranking Amps battsup C3 Tech/Performance 11 10-24-2002 07:01 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    Sponsored Ads
    Vendor Directory
    • Ask a Question
    Question Title:
    Description:
