HEI Distributor
Old Feb 26, 2013 | 01:00 PM
doctorgene's Avatar
doctorgene
Default HEI Distributor
Good morning. When you install a roller Cam, you have to install the gear on the bottom of the factory distributor. The factory makes this gear, which I have used,. If you have a Mallory, or one of the other Distributor, do you have to change those Gears also??? Thanks I Appreciate. Gene
Old Feb 26, 2013 | 01:07 PM
Korevette's Avatar
Korevette
I am using an engine that asks for a 'mellonized' gear. I don't know if this is what is required for your application.
To get some info I went to the manufactures website, MSD to look for some answers. Maybe Mallory's site might be able to tell what is needed.
Old Feb 26, 2013 | 01:40 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Depending on what cam you have, you may not need a special gear.
If you have a cast iron (SADI) core, or a billet cam with a pressed on cast distributor gear, then a normal gear can be run on the distributor.
If you plan to use a billet cam core (with a billet gear) then you will most likely need to change gears on a Mallory distributor.
To HEI Distributor
