Looking to dot the i's and cross the t's on an engine refresh
Cooling System?
Our C3s do not shed the heat very well stock. You might want to think about upgrading your cooling system. An engine that runs @ 180* will be run better than one that runs at 220*. 30* leaves some power and mpg on the table.
A mag did some temp testing on this. There was a 20hp diff as I recall.
Of course nice elect fans might need a bigger alternator. The chase goes on! lol
R
R
R
R
I already have a DeWitts aluminum radiator and it runs very solidly at 180*. I am doing the conversion to electric fans (and CS-140 Alternator upgrade) as well during this cycle.
I also will be Jet Hot coating my headers to keep the heat down.
I agree on the heat sheddding.
Now if you want to keep the cabin cooler look into insulating the floor and the firewall under the carpet. That combined with some fat mat mega mat sound insulation really makes it nice to drive. Every little thing helps. Mine is black so I also got the windows tinted as dark as legal which helps lots to keep cool on sunny hot days, pretty much the only time I drive it.
Those are all good ideas to keep the heat down under the hood. My Hooker headers are jet hot coated inside and out. The quality of the coating is very good, both looks and durability. I also have the Dewitts direct replacement alum radiator and it works excellent and the quality is superior to any other aftermarket part I have put on the vehicle to date. I struggled with the stock rad for quite a while, adding electric fans, extending the front air dam, flushing it out etc and all helped a little but the radiator was really the key to getting the operating temps down.
Cabin is nice and A/C is just fine
Done. When i tore out the interior, I replaced all the seals, put down sound insulation as well as reflectix under the new carpet.
