Carb help
Carb help
Quick fuel 750 vac secondaries .
ZZ430 clone I did over this winter.
Timing set all in at 2800 36 degrees ,, BUT I am using a harbor freight timing light.
(first road test had to get gas )
My issue: If I take motor rpm up in a steady rate it pulls and goes really strong.
However if i nail it I am getting popping out of carb . once that clears the car pulls like a gorilla (I have never encountered a gorilla so take that for what it is worth)
Any ides where I should start to figure this out would be sweet !
Mod you can delete this topic I fixed it ...........................
What was the issue?
It was the timing ,, so far off because i had pulled dizzy a month ago and forgot all about having to time it again..Now ya drop the hammer and the nail gets set.
