2004R Line fitting sizes?
I need to get my new 2004R cooling lines run and bought a set of stainless hardlines from the trans vendor that were supposedly custom bent for the vette. You guessed it, they don't fit, not even close. So, i'll return them and I was thinking I'd run stainless braided PTFE lines from the trans to the radiator instead. Question is what size are the fittings that I need to hook up the lines to the trans? I'm guessing -6 AN but....
Any reason not to use braided stainless for this application?? Summit sells 20' of the stuff for less than I paid for 6' of hardline.
Thanks!
Thanks!
No fan of braided hose- I've changed too many hydraulic lines in totally silly spots on large airplanes that were leaking. 3K PSI systems there.
That said, make sure the hose is rated at 2-1/2 times the max system pressure, and for the maximum temp the trans will see. (At 300*F the trans is going to have a meltdown)
Overall, it's pretty simple to bend and flare the brake tubing they sell at the parts stores. So easy that buying prefabricated lines makes no sense to me at all. Lars has a paper about making fuel lines.
That's a roger on those hydraulic lines on planes (pigs). LOL!
Thanks,
Greg
Take a look at this site. I am thinking of other solutions to metal lines as well but have not pulled the trigger. The turbo buick guys all use the 200-4r and are almost all racers.
http://turbobuick.com/forums/threads.../#post-2673226
http://turbobuick.com/forums/threads...2/#post-295164
http://turbobuick.com/forums/threads.../#post-3103834
You can bookmark this page for future searches and deep dives...
http://turbobuick.com/forums/forums/...ssion-talk.12/
Greg
IIRC, GM used steel for all but the last 12 inches or so of the cooler lines. They used a rubber hose from in front of the right control arm(s) to the radiator and then short metal tubes from the radiator. Got to have some flex in there.
If you go with the braided hose, make sure it's temperature, pressure and fluid compatible, and clamp it down so it won't get into anything. Flex hoses have a way of moving on their own and rubbing against anything electrical or sharp.
