What grease for the windows?
I'm finally rebuilding my power windows and need to know what grease is best for the tracks and wheels. What about the grease for the motor gears? Thanks!
Received 1,468 Likes
Cruise-In II Veteran
I used white lithium because I had a tube of it.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I believe white lithium is probably your best bet but I will defer to someone else for a second opinion.
Received 2,878 Likes
Hi,
Third opinion... white lithium.
I got some in an aerosol can with a long thin tube on it so the grease would end up where I thought it should be.
Regards,
Alan
Regards,
Alan
Thanks guys! White lithium it is. I want to do it up right since I'll have it apart with all new pieces to go back in.
I did this to mine (which had been sitting for 6-8 years) and the power windows went from barely moving to going down so fast I was actually concerned the window was going to break when it hit the stop. Definitely find an aerosol with a tube so you can direct the spray. I started with my door panel off thinking it would create better access but realized it was easier to just shoot it down from the top window channel.
Ill go against the crowd here and say WD40... I found that over the years most grease (white lithium included) gathered dust and dirt and actually made it harder to roll my windows up and down. I just did power windows and used a nice coating of WD40 on the tracks and rollers. Fast, smooth, and it will stay like that
I prefer the clear dielectric grease applied after cleaning the tracks thoroughly while out of the car.... most prefer lithium which I find to be messy in appearance and application when it squirts in the wrong spots. When Alan 71 does it though, it's done right just like all his work. to you Alan
Last edited by rjag; 09-29-2013 at 11:43 AM. Reason: Forgot to put Instant email notification before posting
Location: Where it's always hot as Hell-South Louisiana.
1 Post
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I have a 2 page story of how I learned this the hard way, but thats for another day. Just remember that the windows will NOT run up/down fast at all if the engine isnt running.
White Lithium Spray with the short tube for direct hits !
White lithium...but only from a tube. The spray stuff is VERY thin and doesn't actually put much lubricant where you spray it. The window mechanism needs a good amount of lube to keep it from binding up.
Wheel bearing grease in the motor/gear box....
but on the tracks.....NOTHING!!!!!! mine been that way for some 18 years now, except for the spring breaking, never an issue....last spring Put on, I painted several times....slo the rust a little, anyway....
That's interesting. I had the regulator for my driver's door out last week. It still had a significant amount of the grease from the factory still on the rails and rollers.
Personally, I think lube is better than no-lube....
guess what? 18 years later those same rails are fine with NO grease and crap to dry out and collect dust.....
that whole idea of greasing where a nylon ROLLER rolls is just silly, in fact it sounds like a built in maintenance issue from the factory....
and it's NOT the only car I have issues with this over the DECADES@!@!!!
Glad that's worked for you...
White lithium is what they use on new cars these days. It will eventually dry out and become sticky/gummy, but you're talking 20 years down the road. I actually just had the door panels off my 11 year old '02 C5, and the lithium grease on its tracks was still slick as snot.
I wouldn't use wheel grease for fear of it attacking any plastics in there.
WD40 isn't actually a lubricant and will dry out rather quickly.
Using teflon bike chain spray (or even the dry wax lube) is a good thought. I might try that one day.
