just started making this noise
Old Apr 30, 2013 | 05:46 PM
C3Ohio's Avatar
C3Ohio
8th Gear
Default just started making this noise
New here. Just started making this noise the other day but not very long and went away. Changed the oil and it came back. Holds 40 psi oil pressure same as it always has. Vortec heads, 1.6 ratio harlan sharp rockers and a stock cam. If i adjust any rocker it seems to stop for a second, then back again. It ran fine all last summer.
Old Apr 30, 2013 | 05:55 PM
Bagmup's Avatar
Bagmup
Maybe collapsed lifter??
You dont seem to have much oil up top either. The various SB i've owned over the years, made a god awful mess if i ran them without a rocker cover..
Old Apr 30, 2013 | 06:00 PM
aaroncorvette's Avatar
aaroncorvette
As above, my engine bay would have been covered in oil in that short time.
Are you sure you have enough oil in there? Blocked oil ways? Bad rocker adjustment?
Old Apr 30, 2013 | 06:12 PM
hugie82's Avatar
hugie82
Sounds like a collapsed lifter to me too. It even looked like #1 exhaust was the tapper. Push on it with a hammer handle and if it changes tone, that's it!
Old Apr 30, 2013 | 06:16 PM
Phil Zell's Avatar
Phil Zell
Either a valve too tight or an exhaust leak. I am betting on the exhaust
Old May 1, 2013 | 02:28 PM
C3Ohio's Avatar
C3Ohio
8th Gear
I was thinking collapsed lifter too. And now that you mention it, it did used to cover my engine bay with oil when i ran it wit a cover off. Today i started it and there was no noise. Sounds like its time for a cam upgrade.
To just started making this noise
