holley pump cam choice for an L88 engine
Old 05-29-2013, 11:36 AM
elle88
elle88's Avatar
Default holley pump cam choice for an L88 engine
I feel that my engine is not powerful and crisp as it should be when i accelerate in 2nd or 3d gear . At high rpm is a beast but i believe it can do better at lower rpm and i start to think the problem may be the holley pump cam i'm using
here is the holley pump cam chart and my engine specs
441ci , ZL1 cam , 11:1 CR , 4.11 rear end . 510hp dyno. 38deg total advance
carb :
Holley DP 850 annular boosters
discharge nozzles : 35
primary pump cam :pink
secondary pump cam : brown with 50cc acceleration pump
i increased the squirters from 31 to 35 but no big effect.
if you see the graph , you see that the pink cam is probably too much progressive and slow... is it reasonable to think that the green cam may work better in my situation?
am i wrong or the pink cam seems more intended for a vac secondary carb , where there's no secondary acc pump so the continuus and straight slope of this cam supplies fuel till wot ?
would instead the green cam be more suitable for a double pumper ?the green cam supplies all the fuel quickly then quits when the secondary opens ( with its own pump)
before spending lot of time trying these cams , i would like first to understand
Old 05-29-2013, 11:58 AM
scottyp99
scottyp99's Avatar
It's pretty easy to replace an accelerator pump cam, why don't you just give it a try and see what happens?
Check out this link:
http://forum.grumpysperformance.com/...hp?f=55&t=1790
Scott
Old 05-29-2013, 12:43 PM
elle88
elle88's Avatar
Scott
thanks for the link
for various reasons i cannot make any carb test before september...and i would like to hear forum's members experience and toughts about how these cams work
Old 05-29-2013, 04:42 PM
TCracingCA
TCracingCA's Avatar
Received 1,683 Likes on 1,005 Posts
Default First!
What intake manifold?
Old 05-29-2013, 06:23 PM
elle88
elle88's Avatar
GM dual plane with a thin carb spacer that allow some communication between the 2 planes
Old 05-30-2013, 12:19 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
looking at the original 4296
.035 pri and sec nozzles
218 pri cam in #2 position
6.5 power valves
stagger jetted pri 78C/82T sec 82C/80T C=Choke, T=Throttle
Old 05-30-2013, 08:20 PM
gkull
gkull's Avatar
Received 1,329 Likes on 1,057 Posts
I think that you are looking in the wrong place. by the way I have the pink cams on my 825 demon
The squirters and power valve only come on at the hit of the throttle to enrichen the mixture.
You might need to replace the little rubber squirter plugs. They do go bad every few years.
bigger diameter squirters only serve in masking the real problems and all you end up with is a big blast of black smoke on the hit of the throttle. The arms have to adjusted so tight that on the smallest move of the throttle you see wet dribble looking in the bores with the engine off. Anular booster like what you have are better for a linear A/F ratio, but they do cut down on the total CFM. Wood 1/2 inch 4 holes give the best signal and work as a thermal barrier. That little piece of aluminum does nothing
Annular boost
Old 05-30-2013, 08:32 PM
Rebelrob
Rebelrob's Avatar
elle88, I had a Holley 850 DP. I just could not get it tuned right, but then again, I probably did not try hard enough. I upgraded to a 50 CC accel pump on the primary side which matched the 50 cc pump on the secondary. I found that if you used any other cam besides the yellow or maroon ( I think it comes with) then you have to bend the accel pump arm. That's when I got into trouble and F.... up the arm. I did put the pink cam on once and the throttle was very crisp but ran out of juice after around 3000 rpm. I went with a vac sec 750 for now until I get some good miles on the engine. I will try again.
Old 05-30-2013, 10:16 PM
HBZ_81_C3
HBZ_81_C3's Avatar
What cc pump is on the front? What is the measurement between the pump arms and the adjuster.
I'm betting the cam isn't the issue.
If you have a 25cc pump on the front swap them.
Don't know what heads you have, but I bet that big block would like some more timing too.
Old 05-30-2013, 10:30 PM
gve
gve's Avatar
It might not be your carb at all, if you have rectangular ports they make there hp at higher rpms which is where you say it has power, also it depends on how your cam is degreed.
spdrcr29 (05-11-2019)
Old 05-31-2013, 12:21 AM
GDaina
Support Corvetteforum!
GDaina's Avatar
Your carb has nothing to do with your low end performance...you have a cam with hardly any low end, you are running huge square port heads with hardly any low end....it is what it is...once you hit the upper RPM range, as you say, it is a beast....
You might want to try different transmission gearing if you are running a Muncy close ration...
Old 05-31-2013, 12:26 AM
TimAT
TimAT's Avatar
MY question too- what RPM are you trying to accelerate from in 2-3 gears? Your cam may not really hit it's mark until about 3000 (Guessing a bit- I have the factory ZL-1 cam and it starts coming on about there). What RPM range did the cam manufacturer say? Mine's as soggy as a wet sock until about 3k- and then it wakes up.
Old 05-31-2013, 12:37 AM
dmaxx3500
dmaxx3500's Avatar
Received 1,183 Likes on 748 Posts
is your intake divider cut out in the top of the manifold,i remember talking to a GM engineer at elkart lake race track 20+ years ago[i was pitted next to his ''can am car''] and he was showing me the zl1/l88 factory orignal engine,and they were using a 3 barrel 850 cfm carb[they got better top-end],and they cut the divider in between the left/right sides down 1-1.5'' ,,i'll try to get a few pics of an orignal L88 manifold i have on the shelve,
Old 05-31-2013, 02:14 AM
elle88
elle88's Avatar
@Tim
i think you are right.The cam is what it is
i mean accelerating when i'm between 2000 and 3000 rpm
i will try a couple of different cams anyway , possibly the white ( as MelWff says it's in the original L88 carb ) and the green or blue.
If i'll see no big difference, i'll go back to the pink that seems the most general purpose one
Tim , i think you sold your LS7 ....do you recall which pump cams on your carb?
@Gkull
which are the rubber squirters plugs? i don't see them . carb is new
no space enough for 1/2 wood spacer
now i have about 3/8" spacing counting all the stuff sandwiched between the carb and intake.
so there's about this 3/8" gap that puts in communication the 2 planes of the intake
@dmaxx3500
so as you can read i don't have the single plane L88 intake. choice made to avoid too few low end TQ
So
the original L88 carb had the white cam on hole 2
Gkull has the pink one on the 825 Demon
other forum members?
Old 05-31-2013, 09:00 AM
GDaina
GDaina's Avatar
if you're going to try different cams, look at comp cams Ar288 street roller...power throughout the entire RPM range and idles at 850 rpm
Old 05-31-2013, 09:04 AM
elle88
elle88's Avatar
i meant accelerator pump cam tests.... the engine cam is and will remain the ZL1
Old 05-31-2013, 11:23 AM
TimAT
TimAT's Avatar
I still have it. Same as always. I'll look when I get home to see what pump cam is on- may not make any difference- I'm running a Demon 850.
I am building a new engine- pump gas friendly, more cubic inches, more cam. I figure what I lose by dropping compression, I'll more than pick up with the other parts. Block is at the machine shop waiting on lifter bore bushings.
To holley pump cam choice for an L88 engine
Old 05-31-2013, 02:10 PM
gkull
gkull's Avatar
I was reffering to the Umbrella check valve. If it is old or torn you won't get a good pump shot.
http://www.holley.com/types/Accelera...ce%20Parts.asp
Old 05-31-2013, 07:37 PM
GDaina
GDaina's Avatar
That won't solve your low end performance....all that will do is prevent off idle stumble, and if you don't have a stumble starting from a dead stop, why bother changing?
Old 05-31-2013, 08:55 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
I'll get back with you on this...
Quick Reply: holley pump cam choice for an L88 engine
