I posted a couple of new engine pictures on my web page. I took them when I was up at my engine builder last week. The single dominator motor is a 622 tall deck truck block,with canfield heads. Made 1100HP at the rear wheels with two nitrous systems. It's in a 58 chevy wagon all steel 3500lbs runs 5.50 at 129 in the 1/8.
The twin dominator motor is a 632 Aluminum block,big chief heads,sheet metal intake and three nitrous systems. Makes close to 2000HP. It's a bad butt!!! Cost $30.000+ for the motor. :eek: The camaro run's mid to high 4,s at 155 in the 1/8.
I know the engines are not in corvette's but I thought you guys would like to see them.
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Re: 600 cubic inch (subboz)
Seeing those mega cube rats sorta gives you an idea how truley impressive Monty's motor is. Same HP, more torque, streetable, pump gas, small block. :eek:
