oil pressure sending unit
Old Aug 28, 2013 | 09:41 PM
archer417's Avatar
archer417
Default oil pressure sending unit
Used the search function but just got back info on newer cars.
Before I replace the sending unit I just wanted to ask. I seem to have plenty of pressure running between 30-60 but the needle is not steady. It seems to vibrate or jump around erratically. The variation isn't that much, 10-15 psi but it's irritating.
Should I replace the sending unit or am I just paranoid.
Old Aug 29, 2013 | 01:35 AM
7T1vette's Avatar
7T1vette
The sending unit wire has fatigued somewhere (probably at the connector on the sending unit) and is likely sending intermittant readings which cause the needle to jump around.
With the engine off, but key in "ON" position, have someone wiggle that wire while you look at the gauge (or vice versa). If you get it to jump from high to low, the sender wire is defective....most likely in the engine compartment.
Old Aug 29, 2013 | 06:24 AM
oldschoolvette's Avatar
oldschoolvette
could be loose connection burned / frayed wire. If you are going under there the sending unit is not that expensive and easy to replace. Not sure you need to but it buys peace of mind
Old Aug 29, 2013 | 07:58 AM
archer417's Avatar
archer417
Thanks guys!
Old Aug 30, 2013 | 01:06 AM
Ely's Avatar
Ely
I was told that the gauge has an oil dash pot to it. The oil helps to eliminate the bouncing. This is a common thing used in race applications and often used in boats. A simple check is to turn the car to the "on" position and shake it. Does the gauge move? It could be a lose wire as stated above but I would check the possibility of a low oil condition of the gauge as well. I'm told that some of these old gauges were filled with oil or alcohol that would evaporate over time.
Let us know what you find out.
Old Aug 30, 2013 | 01:41 AM
7T1vette's Avatar
7T1vette
I don't believe that any fluid-dampened gauges have been installed in Detroit-built cars in the last 70 years (or more). Fluid-dampened gauges are common in industrial environments, where pressure spikes are present.
Old Aug 30, 2013 | 08:48 AM
Ely's Avatar
Ely
You misinterpreted me or I didn't make myself clear. Sorry. The gauge it self is not fluid filled. It is fluid damped. The back side of the unit has a damping feature. I learned this from a thread that Wilcox Corvette posted. Sorry I can't find it now but it had to do with an OEM C3 fuel gauge. I recall him stating that the fuel gauge was damped this way.
I fond a drawing that Wilcox had. See below. Note the "damping oil". I'm pretty sure that all gauges have a damping feature. I know the gauges that you are talking about that are used in factory applications. You can see the damping fluid in the face. I agree Detroit has not used that style in a long time.
To oil pressure sending unit
