C3 Convertible deck lid Latch Rod and Lever
you could probably cut out the inside of that 4 inch or so circular recess the bracket straddles. then get 1/4-20 versions of these nuts and grind them down to about 3 or 4 threads high and grind off the points that sink into wood. then drill holes just outboard of the cutouts and slip them in and epoxy them and bolt them down while epoxy cures. then you will have machine screw mounting points.
mashmc (11-04-2017)
As for making this plate ...for me that is not a big deal once I know its measurements Getting it attached...I can think of several ways of attaching the plate...some are a bit extreme while other methods are quick and easy.
I know I would make a steel plate that has been threaded so machine screws could be used and slide it into the area where I could install the machine screws and hold it. I know that is a bit extreme...but I like a challenge....because some of the other methods of securing it I thought of could work well also. But I have found out over the years of doing this stuff...I find that sometimes the easy way may not be the way that lasts the longest or is best...in my opinion.
DUB
mashmc (11-04-2017)
Hey thanks for the tips, I was afraid it maybe part of the Deck Lid and figured it would be costly and difficult to locate. I like the "T" Nut suggestion a lot and will go to my fastener house Monday. I'll fab the bracket and pivot attachment. I think I have got my answers and will share the end results with photos when completed. Thanks to Alan, Gusto, Dub, and Dereck, this was greatly appreciated,
Best Regards
Larry
Best Regards
Larry
Last edited by mashmc; 11-04-2017 at 10:53 PM. Reason: Add another CF Senior Member Dud
I did not want to mention these ...but they can do what you need and not have to cut into your body.
DUB
DUB
There are fasteners called Riv-nuts or blind fasteners. They install similar to pulled rivets but have threads on the ID of the riv-nut. They act like the rubber well-nuts DUB posted but are metal and permament.
This is close to the setup I have.
You see you pull the riv-nuts like a pop rivet. I've never tired to set on into fiberglass but it should work since the deck-lid is pretty thick.
I am aware of the riv-nuts. I sue then but I use them on steel...not fiberglass. And I do know that GM uses then in the SMC doors for a C5 Corvette.
But I still do not like the idea of this riv-nut squeezing against fiberglass. And the fiberglass can give way. The ONLY way I would do it is IF I had a stainless washer that would be on the backside of the riv-nut. But seeing how that would be about impossible (without cutting the deck lid open to do so). I would not do it.
I honestly feel that a nut plate can be fabricated and slide into that area and used and no cutting of the deck lid needed.
DUB
DUB
Deck Lid Missing Bracket
This was great, I learned so much from this forum! I never realized how many different fasteners there are available to fix about anything. Here is what I finally did to add the missing bracket. My opinion is: the original 4 rivets were not for strength but were to hold the bracket in place during the molding process. The raised panel frame completely hollow, and about a 3.2 mm thick. I decided to make a bracket from aluminum, bond it to deck lid with resin/epoxy and rivet in place. I have attached all my new components and adjusted it so that the convertible top is released separately from the deck release. It all seems to work properly and I will reinstall to my Vette this weekend. I again woul like to thank everyone that provided me with the suggestion that made this possible. No I am not trying to be concourse since it is a 1982 Crossfire Topless Vette.
Thank you Larry
Thank you Larry
At least the judge can get the deck lid open to complain about it now... nice fix! Not concours, but Bubba's not here man!
With the pop rivets and an adhesive to hold it also. I am sure that the flat piece of aluminum will never move on you.
Glad you took the time and did it yourself. I know you must feel some sense of accomplishment!
DUB
DUB
