What transmission fluid to use for a 1976 stingray?
I have a 1976 corvette with a L-48 transmission, I need to add transmission fluid but have no idea what kind it takes. I believe it use to be Dextron 3 but a lot of auto stores are telling me I can also use Dextron 6 now which is the same as the old Dextron 3, not sure which one to buy, any suggestions would be appreciated..
Dex/merc or Dexron 3 will be fine, you don't need the Dexron 6
The guy at auto zone told me good luck trying to find Dexron 3 and tried selling me Dexron 6 for $10 a quart. I knew they still made Dexron 3, have no idea why he said that the Dexron 6 replaces the 3.
Uh, L48 is probably your engine. Just to be clear, do you have a TH-350 3-speed automatic transmission, or a 4-speed manual transmission?
Red and slippery. Add a bottle of Lubegard red. Or if there’s a leak problem, add some Lucas Extend.
https://www.lucasoil.com/product/aut...d-conditioner/
https://www.lubegard.com/products/platinum/
I’ve used either depending on the situation. Lubegard to smooth the trans operation, enhances shifts. Best additive since Trans-X.
Lucas has the stuff (MEK) to swell seals and slow leaks.
Steve O.
I did assume automatic, too….
Steve O.
Walmart, just under $20 for a gallon. Use it in my wife's 66 Pontiac. States dexron III. Dexron-VI is compatible with older vehicles whose automatic transmission uses the earlier versions of Dexron.
The main difference between Dexron 3 and 6 is that, the Dexron 3 is a regular ATF and the Dexron 6 is the upgraded and synthetic automatic transmission fluid. 6 has better foam resistance and sheer stability.
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I like Mobil 1 synthetic atf that meets Dexron requirements. Among other benefits, it handles heat much better than the standard atf.
