Headers ,,,
Old Nov 19, 2013 | 07:09 PM
diehrd's Avatar
diehrd
Default Headers ,,,
What primary tube size headers do most of you guys run on the Small Blocks ? 1 5/8 ? 1 7/8 ? any one using 2 inch primaries
Old Nov 19, 2013 | 07:10 PM
qwank's Avatar
qwank
I'm running 1 5/8" on my stock engine.
for your car I would go with 1 3/4'' or 1 7/8'' Hooker super comps
Old Nov 19, 2013 | 07:17 PM
diehrd's Avatar
diehrd
I can get a set of 2" but I never have seen or herd of anyone using that size
Old Nov 19, 2013 | 07:39 PM
bluedawg's Avatar
bluedawg
I'm running 1 5/8"" primaries on my 400" only cause that's what I had used on my 350" but 1 3/4" are in the plans. I think at 377 or larger turning 5800 or higher that the primaries size increases. 2" would be a spin to fit on non spread port exhaust, and probably wouldn't help until atleast 421".
Old Nov 19, 2013 | 07:52 PM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
You better be spinning that bitch to the moon to need 2" primaries on a small block!
Seriously though, not much of a need beyond 1-3/4" on most small block motors. Hell, I only have 1-7/8 on my 650hp 496 and don't feel they are undersized as I could have opted for larger.
Old Nov 19, 2013 | 08:00 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
This rookie is trying to imagine how to get the header bolts screwed into stock heads when using 2" tubes!
Old Nov 19, 2013 | 08:10 PM
diehrd's Avatar
diehrd
I have the fast burn heads , I am going to go with a 427 SBC end of next fall ... I have just never seen 2 inch primaries on sbc headers .. Sorta caught me by surprise they are even available
Old Nov 19, 2013 | 09:33 PM
qwank's Avatar
qwank
ah, now i see why
Old Nov 19, 2013 | 10:56 PM
vetteguy22's Avatar
vetteguy22
I have 1 7/8 tubes on my gen 1 small block 427 running 603hp.
Old Nov 19, 2013 | 11:12 PM
ezobens's Avatar
ezobens
1 3/4" Super Comps on my 409 SBC.
I initially tried using 1 5/8" but it was covering part of my exhaust ports (Profiler 195 heads) so I had to step up.
Old Nov 19, 2013 | 11:14 PM
diehrd's Avatar
diehrd
HAve any of you guys ever seen a 2 inch sbc header or know anyone who used a set ?
Old Nov 19, 2013 | 11:53 PM
68post's Avatar
68post
That's race smallblock territory. Years ago we had a stockcar for a local short track and our next engine was to be a 407" and it was to me to choose between 1 7/8" or 2" headers with the HP peak around 7,000.
I would have used 2" to kill alittle bottom-end, we had an approximate 3 second acceleration window (corner to approximately mid-track) and a narrow rpm range, (1/5 mile oval or figure eight ). We would've needed HP over torque for a push above 5,500
Both partners bailed and the 407 didn't get built. Hope that helps point to where 2" territory is,( imho ).
Old Nov 20, 2013 | 07:08 AM
tektrans's Avatar
tektrans
2" primaries maybe for 1000 hp set up.
I can tell you that I went from a 1 3/4" primary tube to a 1 7/8" primary tube on my old 750hp LSX 441 motor and I gained absolutely nothing-Zero.
Keep in mind a 2" primary will need a 3.5" collector if I'm not mistaken and that will kill low end torque on a hydraulic roller setup.
Now if you are building your 427 as a high spinning solid roller with a bunch of nitrous then yes a 2" primary and 3.5" collector makes sense but if you are building a 427 hydraulic street/strip motor I think its a bad choice jmho.
Old Nov 20, 2013 | 07:12 AM
diehrd's Avatar
diehrd
It is 2 inch primaries collecting to 4 inch and then exiting at 3 inch .. I do not need to buy them I can go with 1 7/8 or 1 3/4 ...
Old Nov 20, 2013 | 07:24 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Just my $0.02 worth, if you're on the street, and through mufflers, the 1 7/8" pipes are probably overkill. If it were me, I'd go with the 1 3/4" pipe diameter, OR maybe a stepped 1 3/4" to 1 7/8" design, if you can find one for a C-3 chassis.....
Old Nov 20, 2013 | 07:31 AM
diehrd's Avatar
diehrd
How would using these sized headers affect me if under car I was at 2.5 . . Or 3 inch pipes
Old Nov 20, 2013 | 08:58 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Would be an absolute waste of time. 2" is for insane nasty high RPM screamer small blocks with incredible heads and/or nitrous. You don't stuff 2.5" pipes behind something like that.
A 2" header will require adapter plates to bolt to the heads.
They will also shove TQ peak way up there. Not so much as change the peak RPM number..but it will definitely be lower under peak TQ. They would help power hang on past peak TQ if you were going 8000 RPM plus.
JIM
To Headers ,,,
Old Nov 20, 2013 | 04:06 PM
tektrans's Avatar
tektrans
Dont buy them. 1 3/4" would be ideal IMO.
Old Nov 20, 2013 | 05:27 PM
diehrd's Avatar
diehrd
Thanks guys !!!!!!! Glad I asked it is nice to get some good advice on this forum
Old Nov 23, 2013 | 05:12 PM
diehrd's Avatar
diehrd
Well after looking around , asking and checking a lot I did order the XS 2 inch primary tube headers , They are stepped at the head and go to a 4 inch collector which will connect to my 3 inch exhaust .. Ill put them on in the spring and let post results
