Torque Thruster II
Nov 25, 2013 | 09:19 AM
Torque Thruster II
I found a set that could be purchased reasonable
question is will they fit my 1972 coupe?
They are 17 x 8 and currently on a C-4.
Nov 25, 2013 | 10:33 AM
you need to know the backspace. if they bolt straight on to a c4 you will need adapters
Nov 25, 2013 | 10:44 AM
And I may have the spacers you need locally. At least you will be able to check them out. Send me a PM if you need to borrow them
Nov 25, 2013 | 11:00 AM
Spacers
What size are they?
Nov 25, 2013 | 09:36 PM
15" Torque Thrust wheels will not normally fit on a C3. They don't clear the brake calipers. Corvette Central sells them for the C3 but they are specially manufactured by American Racing for them so they fit, and they charge accordingly. They sell for about $250 pop. The 17" should fit if the backspacing is correct.
Nov 25, 2013 | 09:47 PM
Tt ii
Thanks for the info.
Nov 25, 2013 | 10:02 PM
Nov 26, 2013 | 11:34 AM
So, what's the backspacing? If it's 4", they should work awesome. If they came off a C4, something tells me they won't work without spacers.
Scott
Nov 28, 2013 | 09:42 PM
TT II`s
I will let you know tomorrow we are going to try them.
Also they have 225 55 17 tires does that sound ok if the bolt up and clear?
Nov 29, 2013 | 07:54 AM
TT II`s
They fit close but dont rub anywhere, the tires should ok also. I wait now for his C-5 WHEELS to arrive and mine comes off the stands. I measured these this morning and the appear to have 4` backspacing isnt this stamped into the wheel somewhere?
