Radiator question
Old Dec 31, 2013 | 10:03 AM
GreenDream's Avatar
GreenDream
Default Radiator question
New aluminum radiator ready to go in my 74 automatic. Is the reservoir on the pass side of the radiator actually a reservoir or does it just have tubing running through I? And should I be filling this with ATF?
Thanks..
Old Dec 31, 2013 | 10:18 AM
Mike Ward's Avatar
Mike Ward
There's no reservoir of any type on a '74 rad.
Old Dec 31, 2013 | 10:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by GreenDream
New aluminum radiator ready to go in my 74 automatic...And should I be filling this with ATF?...
After you install your radiator and the AT cooler lines and fire it up, check tranny fluid level.
Old Dec 31, 2013 | 10:55 AM
DonnieP73's Avatar
DonnieP73
Ater you install your radiator and the AT cooler lines and fire it up, check tranny fluid level.
You should have two metal fittings that attach to the radiator that the flex lines attach to from the two metal lines that run from the transmission.
This is on my old radiator.
Donnie
Old Dec 31, 2013 | 11:22 AM
GreenDream's Avatar
GreenDream
Thanks Mike.. and Donnie, that is exactly what I have. I just didn't know if there was any significant volume held inside the radiator. I will just hook them up and monitor tranny level and top off as needed.
Thanks to all.
To Radiator question
