Share Your C3 Upgraded Wheel/Tire Combo's
Old 04-27-2017, 08:20 PM
  #701
SpeedRacerMach
SpeedRacerMach's Avatar
Originally Posted by CA_WxMan
That looks nice. I've been considering these for my '71 coupe.
On these wheels, do you think that a wider tire would fit the the rear, or would it stick out?
I'm thinking 275 in the rear and 255 in front, both on the 18x9.
If I'm correct, that would put the outer edge of the tire out about 1/2" further than yours, and the inner edge of the tire would be about 1/2" closer to the frame rail.
Thanks,
Chris
Chris,
I have to correct my self, these are not 18x9s, they are 18x8s. So the rim width is pretty much comparable to an original 15x8 with the exception of the offset. Originals had a -3 offset, these are a +1 offset which gives me little more wiggle room. But even then it's pretty close to the parking brake cable. So larger tires would probably rub or you would have to relocate the cable or get more positive offset so you have more clearance.
CA_WxMan (04-28-2017)
Old 04-28-2017, 06:35 PM
  #702
CA_WxMan
CA_WxMan's Avatar
Originally Posted by SpeedRacerMach
Chris,
Thank you. That's good info to have before I buy.
I have a spare set of trailing arms, so I may go ahead and rebuild them and relocate the e-brake cable while I'm at it.
Old 04-28-2017, 07:43 PM
  #703
OldCarBum
OldCarBum's Avatar
Received 4,638 Likes on 2,908 Posts
When I fit checked my 17 X 8 X 4" BS I had about 1/2 " clearance between the rim and the e-brake bracket.
Old 04-29-2017, 06:26 AM
  #704
worship79
Support Corvetteforum!
worship79's Avatar
Originally Posted by FKING1
I run 275's all around on 18x9.5. Car is lowered.
No rubs.
Interesting! What's your sidewall height? Have a photo perhaps?
Old 04-29-2017, 10:32 AM
  #705
clwi
clwi's Avatar
This is my ride.
17x8 TT2 with Nitto Invo 255/50-17.
dudleyfj40 (01-03-2020)
Old 04-29-2017, 02:08 PM
  #706
FKING1
FKING1's Avatar
275/35/18
Old 05-10-2017, 02:10 PM
  #707
suprspooky
suprspooky's Avatar
Originally Posted by gjohnson
Nice, Tire/Wheel sizes please, I'm looking at a used set of these Wheels for my 68 Vert. Thx.
Old 05-10-2017, 06:02 PM
  #708
rogernison
rogernison's Avatar
Default Moon roofs
Nice to see a set of "Moon Roof's" on another Orange C3
Old 05-11-2017, 04:42 PM
  #709
gjohnson
gjohnson's Avatar
suprspooky....275/60/15 rear 245/6015 front. Here is a better look at the stance.
Hood Black (03-22-2024)
Old 05-12-2017, 01:37 AM
  #710
JayRay
JayRay's Avatar
I like the 17" and 18" Combos, seems to take the doughnut look out of my 15" wheels unless running BFGR TA's
Old 05-12-2017, 08:59 AM
  #711
The Money Pit
The Money Pit's Avatar
I was considering going to 17's or 18's myself, and wrestled with it for months.....Somehow I can't do it. The 15's just look more "right" to me on the car. L88 hood, and fat back tires......nothing like it.
irongate (07-14-2019)
Old 05-13-2017, 10:01 AM
  #712
SpeedRacerMach
275/35/18
Looks great. How wide are the wheels? 18x8, 9, 10?
Old 05-13-2017, 07:30 PM
  #713
FKING1
FKING1's Avatar
18x9.5 all 4 with 275's rear & 245's frt
Old 05-21-2017, 04:59 AM
  #714
Darth Z
Darth Z's Avatar
Originally Posted by Oldguard 7
Here's my wheel/tire combo.
Replica C6 wheels in C5 size, black chrome finish.
Front: 17x8.5
Rear: 18x9.5
I thought the C5 sizes were 17x9.5 and 18x10.5? I guess I am mistaken. It could just be, because when I ordered a set of Z06 replicas from OEWheels, that was the size I ordered for a different application, my 2001 Z28. I was looking for width, and this set was the widest available. Before I traded a pair of the stock wheels from my first Camaro, and an ex-wife to someone I thought was a friend, I had planned to go with the ZR1's in 17x9.5 and 17x11's. I guess the front wheel sizes of both of these sets threw me off.
Old 05-22-2017, 04:06 PM
  #715
Kubs
Kubs's Avatar
Received 1,716 Likes on 928 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Base C5 and C5 Z06 have different size wheels. The 17x9.5 and 18x10.5 are the Z06 sizes. Base C5 is 17x8.5 and 18x9.5.
Old 05-23-2017, 12:25 AM
  #716
Darth Z
Darth Z's Avatar
Thanks for the clarification Kubs!
Old 06-04-2017, 01:31 AM
  #717
K B Vettin
K B Vettin's Avatar
Originally Posted by Tecumseh
Lt-iii
awesome setup, where did you get the wheels?
To Share Your C3 Upgraded Wheel/Tire Combo's
Old 06-04-2017, 01:50 AM
  #718
K B Vettin
K B Vettin's Avatar
Originally Posted by 682XLR8
Just installed TTII wheels/General tires along with a few other improvements
17x8/245-50-17 in front, 18x10/275-40-18 rear
awesome car, what rear back spacing are you running? is the wheel/tire in the rear outside of the fender at all?
Old 06-04-2017, 02:27 AM
  #719
K B Vettin
K B Vettin's Avatar
Originally Posted by MalibuVLX
Rev classics. 8 x 18 front 9.5 x 18 rear
awesome setup, what backspacing are you running?
Old 06-07-2017, 10:28 PM
  #720
mpopp2002
mpopp2002's Avatar
Front:
Van Steel Aluminum upper and lower control arms
Stock spindles bump steer kit
Wilwood 6 piston nickel calipers and 13" rotors
1" swaybar
JRi double adjustable Coilover Shocks
Forgeline Gx3 18 X 10 wheels with 5.25 backspacing
Falken Azenis 275/35R18
Stock wheel well opening (no flares)
Rear:
Van Steel offset trailing arms
Van Steel Adjustable Strut Rods
Stock half-shafts
Wilwood 6 piston nickel calipers with 12.98" rotors (using stock parking brake)
JRi double adjustable Coilover shocks
Falken Azenis 315/30R18
No changes to location of rear exhaust pipes or mufflers
Quick Reply: Share Your C3 Upgraded Wheel/Tire Combo's
