QA1 coil overs
Old Jan 8, 2014 | 11:46 PM
Vancouver Chris's Avatar
Vancouver Chris
1st Gear
Default QA1 coil overs
was looking to do a front coil over swap on my 78 and got looking at the QA1 set up, I have a friend that runs these on his Camaro and loves them.
QA1 does not build these for a corvette but it has been suggested to me that the ones built for a Camaro should work on my corvette
was wondering if anyone on here could tell me other wise and if they wont work why not
and if it is a mounting issue would it be hard to solve
Old Jan 9, 2014 | 07:28 AM
lakebumm's Avatar
lakebumm
2022 C2 of the Year Finalist - Modified
Check these out.
http://www.speeddirect.com/index.php...tte-shark-bite
BILL
Old Jan 9, 2014 | 07:55 AM
gkull's Avatar
gkull
What you do is buy the single or double adjust QA! front shocks for C-3 Vettes and Speed direct has the spring in 50 pound increments with the aluminum collar for the increased spring diameter.
So if you had 460 coil spring or 550# and liked them get the same from Speed direct.
I wanted no front end dive so I bought 600# for the street.
Old Jan 9, 2014 | 02:25 PM
Solid LT1's Avatar
Solid LT1
I have a set I never used. C2/3 Vette single adj with big block springs $440 shipped to any 48 states.
Old Jan 9, 2014 | 09:16 PM
Ray Y's Avatar
Ray Y
VanSteel has front & rear QA1 kits for Vettes, that's where I got mine.
To QA1 coil overs
