I'm also VERY interested in one but more so for the added security of a parking brake.
Will it work in a parking brake application as well as at the strip?
Gkull I saw a few of your post/threads when searching for this very thing but all your pictures are broken except the one above. Same goes for a few of your other threads I thought looked interesting only to go in and find broken links.
I'm a visual guy so need TONS of pictures and what model people used so I can see how it might look first. Thanks!
The line locks or roll control require electrical power to close the brake line and trap pressure in the caliper. Not a good thing for a parking brake, makes for a battery drain, also not sure if the solenoids are constant rated, may overheat with extended use. They are fun for burnouts though.
