I'm not that familiar with the column shrouds for the later C3 cars. Does it require installation with the column removed from the vehicle? If so, splitting it and re-joining with epoxy and/or fasteners to assemble to the column makes sense to me...if the result is still visually pleasing. Much like the large plastic radiator shroud which is nearly impossible to assemble in a "whole" state.
I'm surprised that the replacement part is not already a two-part assembly, if column removal is required.
