Rear End Vibration. Need Help!!
I installed new poly bushes in my trailing arms about 18 months ago.
Also replaced the strut rod with the adjustable poly type. I had an alignment done front & rear.
(not confident that the rear end was done well).
At first all was good. Then after only a short while I notice a “vibrating” noise that seemed to be coming from the rear end when I cornered, left or right.
I have been trying to figure out where this vibrating noise is coming from & tonight I decided to corner a little harder than usual to try to find out.
When cornering to the left, the vibration was there but not too bad, however, when I turned right, the vibration came up very strongly through the park brake handle.
Any advise as to what could be causing this?
Its got me stumped.
Thanks in advance for any help.
From Down Under
Andrew
Its got me stumped.
From Down Under
Andrew
Not sure, is it possible that the issue is with your park brake. Seems funny that it more noticeable depending on the direction of the turn and vibrates through the park brake handle. I am sure more knowledgeable people will chime in soon.
Ron
Ron
Sounds like bearings at least I would give them a good looking at ,, and if bad I would further give them a good talking 2 ,,, bearings these days are just good for nothings..
My advice covers kids as well and bearings so it is multi useful, cross barrier advice good to make everyone happy .. Except the kids and bearings
Nam Labrat
Received 4,173 Likes
Rookie guess....... bearings on both wheels have too much end-play and the passenger-side E-brake shoes are adjusted out too much causing them to grab more in right turns when the wheel is "lighter".....maybe.......or the transmission rear mount is loose
I had a similar problem with my 68 when I first got it. It had not been driven much for the few years prior. When turning I had a vibration or even grinding sensation from rear end. Turned out to be resolved when I changed the rear end lube (2Qts 08800BOPCK) and added the 4 oz posi-traction additive (08800BOPCKT)(GM parts numbers) picked up at the local Chevrolet dealer. Posi Plates behaving quietly now and no vibration.
Best of luck with it.
On the subject of "kids", we all have those issues.
From Down Under
Thanks for the suggestions.
I will find out how to check the end-play on the bearings & then look at the transmission mount.
Always something to do.
Andrew
That was one of the first things I tried. It made no difference.
Andrew
