best upgrades for l48? More HP?
#41
Drive it first before you start buying parts. You may be surprised at what it can do stock (assuming in a good state of tune)
r
#42
Kits start at $1650-ish, add exhaust, add ignition system.....
possumd (11-24-2018)
#45
Buy a whole brand new GM motor for under $2K and throw some time and ~ $1K at it for all new and close to 400 fwhp.
GM Goodwrench L31 Vortec 4 bolt main crate pn 12530283 (all Brand New NOT reman)... there's some on fleabay at $1825 free shipping includes spend-anywhere $50 giftcard. (maybe local GM dealer will match or beat?) Fleabay seller is Radley Chevy of Fredericksburg VA
get a melonized dist gear ($40), Jegs Vortec intake ($135), change the valve springs-retainers ($150-$225), rockers ($100-200) and Steel Roller LT4 Hot Cam ($200-300) AND pay a local machine shop to finish the fuel pump pad-boss ($100) ...make 375-400 fwhp on pump gas
'74 four speed flywheel won't fit '87-up one piece rear main seal crank ... add a new flywheel ($75)
#50
BIG help.............thanks. I'm off to look at a '74 today......tach, speedo, horn and ac not working, needs manual windows switched to elect... $7500, sounds like too much to me. I'll drive it.if it 'moves'.....maybe worth $5k ? We'll see. Thanks again.
#52
Also,seems the above x283 Vortec crate-Hot cam combo's likely to be as strong or stronger than any OE sbc vette 1971 thru 1982
yaaay ... CFB for fifth straight year, #2 Clemson crushes Carolina ... yaaay
#54
1977 stingray l48 350 automatic...would like to add more power to the stock engine, what do I need? would like more hp and make it sound louder and meaner lol
in the mean time - here's a video of my buddies doing a test drive after we got it running, nsfw as there's an F-bomb or two in there
#55
Yes, the 73-80 L-82's are all basically the same exact motor with different exhaust systems, carb tuning, and timing...THEY ARE THE SAME MOTOR! and not much different than a 71/72 LT-1 engine...that is the dirty little secret about C3 SBC engines....for the C3 corvettes. The only real impressive SBC V8's in C3's are the 69 L-46 350/350 and the 70 only LT-1 with 370 gross HP......
Primoz (11-25-2018)
