Edelbrock Rpm top end package?
I have an 81 vette with a 355, with flat top pistons, edelbrock performer cam, intake and carb. It's a great little motor but like everyone else I'm wanting a little more gitty up and go. I've been looking at the Rpm package that comes with cam, heads and intake. My question is, does anyone have this set up? The pros and cons? And what kind of clearance do you have?
The Performer RPM is 3/4 of an inch taller. I did go from a 3" element to a 2" element but it fit fine.
My other suggestion is unless the Edelbrock comes in a hydraulic roller cam, I would suggest looking at Lunati cam.
Ken
my middle son Chris just put in a Edelbrock RPM heads and cam package on his 98 C4,
Charley at RPM motor sports is doing the Dyno tune on it, we will have numbers by Saturday. im hoping for 375hp and 400tq at the rear wheels... we will see...
Post up your trans, rear gear ratio, cam specs. Might be best off leaving it all as is and spend that $1500 on a set of AFR heads.
Dr. Detroit
Received 3,892 Likes
The performer cam is small at best.....
Try a Comp XE274.....you will pick up at least 30hp...all things considered.....
But yes....give us the whole setup...with gear ratio....
I put headers, the 274...a rejetted Q-Jet, and performer intake on a 77 L-48 and it picked up huge....made it a different car...
Just make sure to curve the Distributor.
Jebby
Jebby
No.... It was his grandmothers before she passed, it's a beautiful clean little c4... Rpm motors sorts is doing the dyno tune this week... I think it will be interesting what the numbers are... I'm kind of excited ,,, it's the rpm package... They claim 400 crank horse... We will see, prof in the pudding.... Stay tuned
1998... C4...
I'm assuming you meant an 88 C4
