electric fuel pump with NOS
Old Jul 18, 2002 | 05:28 AM
vette33's Avatar
vette33
8th Gear
Default electric fuel pump with NOS
hello, I'm going to install a NOS, and I buy an Holley blue elecrtic pump with regulator, i think i have 5 way to install it, which is the best way?
thanks
1)
ELECTRIC_PUMP-------------------REGULATOR-----------CARBURATOR
NOS
2)
ELECTRIC_PUMP------REGULATOR-------MECA PUMP-------------CARBURATOR
| NOS
return ligne
3)
ELECTRIC_PUMP----------MECA PUMP------REGULATOR------------CARBURATOR
| NOS
return ligne
4)
NOS |
return ligne
5)
ELECTRIC_PUMP-------------------REGULATOR---------------CARBURATOR
| NOS
return ligne :smash: :smash:
Old Jul 18, 2002 | 05:33 AM
vette33's Avatar
vette33
8th Gear
Default Re: electric fuel pump with NOS (vette33)
sorry the "|" don't go in good place
for 1) the NOS come from regulator
for 2) the return ligne come from meca pump and NOS from T between meca pump and carburator
for 3) the return ligne come from meca pump and NOS from regulator
for 4) the NOS come from regulator and the return ligne from T between meca pump and carburator
for 5) the return ligne come from regulator and NOS from T between meca pump and carburator
sorry again
Old Jul 18, 2002 | 10:41 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Follow the directions. :yesnod:
Old Jul 18, 2002 | 10:46 AM
QuickVet's Avatar
QuickVet
Default Re: electric fuel pump with NOS (Budman78)
just put the pump as far back as you can. then go to the regulator and into the carb. if you run only one line you need to split it. Split the line into two, then put a regulator on each side and one to the carb and the other to the fuel solinoid. Put both regulator at 7 pounds.
Old Jul 18, 2002 | 10:57 AM
70PurpleLS7's Avatar
70PurpleLS7
Default Re: electric fuel pump with NOS (QuickVet)
To electric fuel pump with NOS
