t top weatherstrip
Old 04-17-2014, 09:30 PM
pnewt
pnewt's Avatar
Default t top weatherstrip
Just finished putting new door glass in my 68 and the t top weatherstrip that the top of the glass rests on is very worn and leaves a couple gaps.. Do I fix this by replacing the T top weatherstrip or just by replacing the outer t top seal? I see both offered for sale but don't know if outer seal is all I need. Thanks Paul
Old 04-18-2014, 07:54 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi pn,
It really depends if the other 3 sides of the roof panel weatherstrip is in good condition or not.
Are the ends of the weatherstrip that will remain in good enough condition that they will make a good connection and seal with the new piece you'll install?
Regards,
Alan
Old 04-18-2014, 08:54 AM
pnewt
pnewt's Avatar
Default t top
Good point Alan.The remaining pieces in the t tops look fine and seal well. The outer portion looks distorted and doesnt fall evenly across the door glass.. Seems like the rear section has shrunk some. I think I'll go for the outer pieces now and when I completely re do the t tops( hardware etc and paint) I'll replace the entire weatherstrip. I wasn't sure if the outer pieces were usable by themselves.. Thanks Paul
To t top weatherstrip
Quick Reply: t top weatherstrip
