Front Starter Brace-Necessary?
Old Apr 29, 2014 | 04:23 PM
Paul L's Avatar
Paul L
Fireball,
I appreciate those pics. The brace obviously went on before the headers!
Old Apr 29, 2014 | 04:24 PM
hugie82's Avatar
hugie82
I never used the brace on a low or mild compression engine. I think I've only seen one aluminum nose cracked on a starter in my life and that was from a backfire from timing being way off.
Old Apr 29, 2014 | 04:51 PM
Paul L's Avatar
Paul L
For my L-48, I am getting that message. But since I have purchased one it won't hurt to install it.
Old Apr 29, 2014 | 06:35 PM
marz's Avatar
marz
I installed my headers today and removed the starter and no brace there. It still has the original starter ( hard to believe) and no brace on it. I have had many many cars over decades and never once had a brace on a starter. The only problem is that the starter is too close to the header so I will be ordering a mini starter. But, as they stated earlier, if it makes you feel safer then by all means install one. Happy hotrodding!
Old Apr 29, 2014 | 06:44 PM
FireballXL5's Avatar
FireballXL5
I bought my vette pretty much the way it is... PO started throwing money at it , pretty much the big ticket items, then I got it and I'm doing the finishing touches... Yes, the headers are VERY close to the starter... The pics do not paint the entire picture there... And , I had to notch out about a 1/4 inch away from the bracket to get this starter to fit for some reason... Old one dropped right out ... Same replacement would NOT drop back in... Had to dremmel with a little cutting wheel...
Since the front brave was already there... I re-used it... As far as the headers and starter being so close... This starter was $49... The hi torque shorty starters looked to be $250-300... Figured I'd go this route for now and see what the longevity is on it...
Old Apr 29, 2014 | 06:49 PM
7t9l82's Avatar
7t9l82
in 1978 my girlfriend bought a new z/28 a year later that brace fell off,2 years later the bolts backed off and the starter was hanging by the cable when she pulls in my driveway. the lesson. keep your bolts tight and you won't have a problem
Old Apr 29, 2014 | 09:36 PM
marz's Avatar
marz
There is the rub. The mini is expensive, but won't heat up like the old large one. It took me all of 3 hours to remove the manifolds, take out the starter and mount the headers...just FYI if anyone was wondering. I don't have mufflers on it and that's why it took so little time to do it. Now headers for my Chevelle. Lots of room there!
Old Apr 29, 2014 | 10:10 PM
7t9l82's Avatar
7t9l82
there are mini starters for way less than that
