Rethinking my 454 re-build....opinions needed...
#144
Preferably without the plastic. They say this is 109 as cast stock. Then they get opened up larger. Then they get decked smaller. Generally when 2.19 put in these, they are unshrouded a bit and that makes them a couple cc's bigger.
#146
Ok, chambers look original untouched. I'll cc a couple of mine tomorrow see what they come out to.
74 LS4-454 (05-25-2018)
#147
Found this head gasket...… .030 and if my calculations are correct......would give me 9.1 CR
https://www.summitracing.com/parts/cgt-c5816-030
#148
OK, so 8 buck chamber cc-ing tool. 4 for the flavor shooter and 4 for a hunk of plexi. I assume anybody messi g with this has a drill and grease. And one of these 215 chambers (1 month before your casting date) came out at 100 once and 102 once. I am gonna do some double checking to verify accuracy and compare a couple more. Cant find my graduates cylinder, but I found a couple similar measuring devices for comparison.
The following 2 users liked this post by derekderek:
74 LS4-454 (05-27-2018),
bmans vette (05-26-2018)
#149
The 215 comes out 100 cc's. But my supposedly 118 chambered 12562934 heads measured 113 cc's I have a few others to compare. Another 118 and 100cc L29 chambers.
#150
118 or 9 cc rated peanut head. Back when they felt 8:1 was too high. Chamber measured 119 cc's. So I guess from 78 to 2000 somebody tweaked this chamber to the lower pic.
#151
Side by side you can see where the older rear head is a little bigger. Bottom pic. L29. 96-2000 pick up, suburban and 310 hp mercruiser. Rated 100 cc's. Measured 100 cc's. So I can assume my low,buck setup is accurate enough.
#152
This will also work to measure piston dome-dish volume, but you will need an accurate distance down in the bore and calculate that volume ACCURATELY.
#153
So we agree on the 215 heads are 100 cc's.... thanks for doing the test......here are some pics and info when I picked my engine up today.....
Picked up the engine today and had a good conversation with one of the machine shop owners who performed mostly all of the work on my engine....... I am extremely happy with their work......here is the breakdown for those who are interested......Crank spect out fine and was polished.....original cam bearing were fine....but were replaced.....Main and Rod bearings were also replaced and new nuts were used on the Rods.....Oil clearances on the Mains are .0025 on the Rods are .002 Cylinders checked out fine and the original pistons were used with new rings.....Piston to wall clearance is .0025. Cylinders were honed on a boring machine with a 280 grit stones.....Quench measured out to be .060 with a .039 head gasket.....Thurst bearing specs are .003-.009 thurst bearing was set @.006 Cam button uses a .040 washer and Cam clearance is @.010- .015 Cam sprocket should have been the 9- key as opposed to the 3- key I have.....Cam was to be set @106.... but was set @107 and will be @106 with chain stretch...
Closest point is @10* BTDC...…...that is about it....if anyone needs brands or part numbers of what was used..... I have all of that info.....not only excited.....but a big learning experience for me.....
bmans vette (06-22-2018)
#156
Bottom end completed.......had to replace pushrod guideplates as the ones on the heads were the wrong size for the pushrods......getting closer each time I go out to the 74......
New on top......old on the bottom....
Size difference between 5/16" and the 3/8" guideplate needed for the 3/8" pushrods....
Perfect fit.........
Oil pump and windage tray install....
#157
Oil pan install....
Test fitting the oil filter....
Roller lifters in....
Pushrods fit great....
Still need to install the rocker arms and adjust the valves.....test fitting the valve covers....very happy with the results.....
#158
More progress yesterday....
Soaking in the cleaning solution....
Cleaned and ready for the install....
Setting up the parts......
Ready for valve adjustment....
#159
More....
Adjustments completed......
Oil deflection pan.....installed and no roller lifter interference.....
Engine getting primed.....oil starting to come through......
