Off the Scale Compression Pressure Values?
Old Jun 15, 2014 | 07:25 PM
CanadaGrant's Avatar
CanadaGrant
With my stock L36, never rebuilt I get between 156 to 161 on a cold engine.
Old Jun 15, 2014 | 08:20 PM
BBCorv70's Avatar
BBCorv70
Originally Posted by scottyp99
That sure does seem like an awful lot of compression for a 10.25:1 CR engine. I'm not all that familiar with LS5s, are the cam specs fairly mild?
Scott
I can't speak for the OP though I'm curious. For me, don't know. I had a machine shop replace the cam many years ago. Don't know if they ever gave me a copy of the specs or even the number of the cam. My engine is actually running 9.6:1 CR, pistons installed to lower the compression, ease issues with pump gas available in the mid 80's.
Old Jun 16, 2014 | 11:55 AM
BBCorv70's Avatar
BBCorv70
Scott
I skimmed a few articles on this topic. It seems higher pressures may be seen when there is less overlap of intake and exhaust valve timing? Interesting...
Old Jun 16, 2014 | 12:24 PM
Flyinace3's Avatar
Flyinace3
I was hoping for 170-180 psi cranking compression on my new engine. After 100 miles I ran a compression check and the results are 205-210, with 150psi on the first bump.Readings on the stock low mile L48 were 170-180.
All test were done on a cold engine all spark plugs removed throttle WFO and about 5 bumps.
New engine specs
Gm Goodwrench 350
Dart SHP180 cut to 62 cc
Pistons .03 in the hole.
.028 gm head gasket
Comp cams xr276hr 59 degrees overlap
9.2 approx static compression.
Run 93 octane and haven't noticed any pinging . timing 10, 30 all in @3000. Additional 20 degrees of vacuum advance full manifold.
From my research my cranking compression is higher than it should be for the amount of static compression I have. I do not know why it is higher than I thought it should be, but it runs strong from 1500rpm up. My tuning knowledge is limited so not much of a safety margin. I've been contemplating a larger cam to lower these levels.
Old Jun 16, 2014 | 10:29 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
New engine specs
Gm Goodwrench 350
.028 gm head gasket
No need to lower the levels. Your in the sweet spot of cylinder pressure vs detonation. The aluminum heads and 9.2 compression is fine with your cams intake closing point.
