Dash Board/gauge cluster wiring
I recently dismantled the console and gauge cluster in my 1975 Corvette.
Problem and or Question. Upon putting back the bulb sockets (single grey colored wire feed) into the gauge cluster, I replace five (5) bulbs into the gauge cluster housing But I found one (1) extra bulb socket that I have know idea where it goes.. There are two (2) other bulbs and sockets but they are for the cigarette light and shift indicator.
Can anyone help me to know where this extra bulb socket goes ?..
Thanks. BigClaw
Thanks. BigClaw
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Lamp for the wiper switch plate maybe?
Willcox
Willcox
Former Vendor
wrong thread.. sorry..
Nope...have the wiper switch plate bulb in place
This lone bulb socket (grey wire) is not amongst the group of wiring that all the other wires are. But this lone wire comes out from behind the dashboard as do the other five (5) that go to the gauge cluster.
Are you POSITIVE that all bulbs are in the tachometer?????
DUB
DUB
Dashboard bulb
I am not sure if the bulbs are in the tachometer. Word is that there are two bulbs in the tachometer (question??..is there two bulbs in the tachometer ?).
I do not have the dashboard removed... I just removed the center console and the gauge cluster.
It is possible that one of the bulbs fell out of the tachometer when pulling on other wires.
I turned on the interior/dash lights and the lower portion of the tach is somewhat darker than the upper portion.
It is my guess that this lone bulb in question belongs in the tachometer.
Thanks for your help !!
JC
JC
Dashboard bulb
It is not the bulb for the Heat/AC or the wiper switch plate. Both of those bulbs are in place.
I think this bulb in question may have fallen out of the tachometer.
JC
More than 2 bulbs...that is a fact...i think it is 4.
DUB
DUB
Received 1,469 Likes
Cruise-In II Veteran
Are you certain the wire color is gray? Do you have the Door Ajar, Headlights, and Seat Belt tell-tales plugged in?
DUB
Finalist 2021 C3 of the Year - Modified
I am guessing right hand turn signal flasher light, i knocked mine out when i was working the the guages ?
Dashboard Bulb
This bulb socket is a single wire grey in color with metal end grippers,know that these leads are for Dashboard illumination.
Long story short...I found where it went... It was a bulb that came of the tachometer. Now back to putting the shift console back together
Thanks for your help.
JC
Dashboard Board bulb
Thanks to everyone who gave some guidance on where this bulb socket may have gone.
After many grueling hours, I found where the bulb socket went.
It went in the tachometer. If you were looking at a time clock, it was the bulb that is placed at 5 o'clock position.
Thanks for everyone's help !!!
JC
JC
