Wiper door shut on wipers
1972 BB, A/C, pb, ps, pb. Haven't driven in rain for a while.
Everything used to be normal. This morning got caught in the rain. Turned lites on-normal. Turned wipers on low- normal ( door opens, arms move ). After a few minutes wiper door shuts on wipers trapping them partially down. Headlites stay normal. Later, turned lites off and they shut. Shut engine down in garage, gently lifted headlite door by hand and wipers retracted to park. Tried to get wipers to operate but no result for door or wipers.
Any ideas where to start looking?
Thanks.
Thanks.
For the wiper door to close, then there needs to be vacuum on the control line to the relay. When there is vacuum on the control line, then the relay directs the source vacuum to the down side of the actuator, then there is no vacuum on the relay, then the relay should direct the source vacuum to the up side of the actuator.
In the wiper bay there is a vacuum safety switch, it's purpose it to stop vacuum on the control line from reaching the relay unless the wipers are parked. When the wipers are parked, and the plunger on the safety valve is pushed, the valve allows vacuum on the control line. If the plunger is not pushed, the vavle will not allow vacuum on the control line, and the wiper door should stay open.
If the wiper door is closing when the wipers are still going, then there needs to be something wrong with either the safety valve, or the relay. My guess is that the spring in the relay has given out and it's not properly directing the source vacuum to the up side of the actuator.
Received 2,878 Likes
Hi k,
Here's the safety switch mash described.
When the plunger is pushed in by the lever on the wiper transmission the door can close.
When the the plunger is out the door can't close because the vacuum signal is interrupted.
I'd agree that the operation of this valve is the first thing to check.
Good Luck!
Regards,
Alan
Plunger pushed in by lever… door can close.
Plunger out …. wipers can operate until they park again and the lever pushes the plunger in which signals the wiper door relay to close the door.
Good Luck!
Regards,
Alan
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have to agree with both post above... Either the safety valve is not working properly or the relay is failing.
Easy to check.
69-72 Wiper Arm Vacuum Relay testing.
Headlamp/Windshield Wiper Actuator Relay testing. 68-72 for wipers.. 68-82 for headlamp.
Easy to check.
Wiper door
Thanks.
Thanks.
Former Vendor
I'm glad you found the issue.. these cars will drive you nuts sometimes..
Willcox
Willcox
68 wiper problem
Thanks Wes
Just fired up my 68 after years sitting and wiper doors won't open .tested motor as per your video and its fine ,if I put vacuum direct to canister they will open .It looks as some has removed the override system under the dash and there is a solenoid with a black and brown wire and one small vacuum line on each side .one side of the solenoid has two ports ,does one need to be caped to work ?
Thanks Wes
Thanks Wes
Former Vendor
on my 68 the vacuum relay in the pass. side fender ,when I use a hand vacuum pump. bleeds off is this normal ?
