The headlight bezel is loose and missing the two upper screws (hence being loose) I don't see what the little screws (2) go into. Is there a clip? 72 Coupe
When you say upper do you mean closer to the hood?
If so then yes there should be a set of clips
M
It's the holes on the upside down pic. I looked at one, and I am assuming now that they are broken off because there is no hole there. I think I could drill them out and replace no problem, but my first look was,..something is missing.
Another question if you don't mind,...if you know. I am ordering an interior part and I am being ask light saddle tan or dark saddle tan. My interior trim plate code just has "417" saddle. Looks kinda darkish to me, but I didn't know there would be a choice. It is vinyl not leather, so maybe one is if leather (dark or light) vs the vinyl.
(change your info using the "User CP" menu, left side of the red-ish stripe near the top of the page, then "edit your details". Just makes it easier for someone to help when they know the details. Also the location, you never know who might live just down the road...)
