Where to buy 90 degree elbow synthetic fuel line?
Location: Las Vegas - Just stop perpetuating myths please.
I need several 90 degree synthetic fuel line elbows in 1/4" and 3/8". Cant use rubber as needs to be alcohol resistant. Any know one a source for these?
Dont know what to call them now that rubber cant work and i dont want to braided line. I want preformed 90 degree elbows that can handle E85 (if i choose it).
I used nickel copper line with an fittings on my new engine and should work regardless of the fuel type.You just need to get a 37 degree flare tool.Standard steel line will also work but it is harder to bend and will corrode.However the nickel copper line is expensive.
I bought a fuel line kit from Dorman for my LS swap. This is the current fuel line used by GM and should work and has plenty of fittings in the kit. Dorman 800-300 Nylon Fuel Line Repair Kit
Dorman carries pretty much anything you might need:
http://www.dormanproducts.com/catalo...disconnect.pdf
Rockauto sells this stuff at decent prices- I just bought a bunch for my EFI project.
