A-arms loaded with shims
Old Jan 7, 2015 | 03:15 PM
RETIRE15's Avatar
RETIRE15
Default A-arms loaded with shims
The camber shaft running thru the a- arms are loaded with shims ,just on the front side .is something bent or does the car just need an alignment?
Old Jan 7, 2015 | 03:46 PM
Alan 71's Avatar
Alan 71
Hi,
Is it 'loaded' on one or both a-arms; and is it on both studs or just one??
An unusually thick stack of shims on just one of the mounting studs is often an indication that something is amiss.
I'd look carefully at the a-arm itself to see if it's "tweaked", and also at the frame rail and crossmember to see if something is bent, creased, or broken.
Good Luck!
Regards,
Alan
I'm still using the original alignment that was on my car when it was new. You can see the amount of shims needed was pretty similar on each stud.
Old Jan 8, 2015 | 12:37 AM
Zero1Niner's Avatar
Zero1Niner
That is one clean engine compartment...wow.
Old Jan 8, 2015 | 08:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "loaded." Post a pic of what you've found.
Old Jan 9, 2015 | 05:15 PM
jimvette999's Avatar
jimvette999
Originally Posted by Alan 71
Hi,
Good Luck!
Regards,
Alan
Alan, do you keep that car in the house? I would.
Old Jan 9, 2015 | 06:38 PM
hwcoop's Avatar
hwcoop
I think its in the living room, looks like hardwood floors under it
Old Jan 9, 2015 | 06:47 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Having significantly more shims at one end of a CA shaft than the other typically means a bent frame and/or that the lower CA mounting point has somehow been moved. The extra shims are most likely there to compensate in an attempt to bring alignment back into spec.
So, first thing to do is to have the alignment checked to rule out bad work. Then, if it's not that simple...
If you have a fairly level floor, some string, a plumb bob, a measuring tape and know how to do, you can get good idea of whether it's actually bent and if the tweak is isolated to the lower CA mount point itself, or to the forward section, or if the entire frame is involved. In any event, if there is a frame or mount problem, you're going to need a well-equipped frame shop that knows what they're doing (make sure they have the correct chassis specs) to fix it properly. And, while they're at it you might as well plan on having them check all datum points. HTH
Old Jan 10, 2015 | 05:51 AM
RETIRE15's Avatar
RETIRE15
Originally Posted by theskunkworks
having significantly more shims at one end of a ca shaft than the other typically means a bent frame and/or that the lower ca mounting point has somehow been moved. The extra shims are most likely there to compensate in an attempt to bring alignment back into spec.
If you have a fairly level floor, some string, a plumb bob, a measuring tape and know how to do, you can get good idea of whether it's actually bent and if the tweak is isolated to the lower ca mount point itself, or to the forward section, or if the entire frame is involved. In any event, if there is a frame or mount problem, you're going to need a well-equipped frame shop that knows what they're doing (make sure they have the correct chassis specs) to fix it properly. And, while they're at it you might as well plan on having them check all datum points. Hth
thank you ,yea the drivers side has 5 shims front side of a-arm and 2 shims on the back .passgr. Side is equal 2 shims each
To A-arms loaded with shims
