So I was driving my 69 the other day and heard a really loud bang. I could not tell if it was a backfire or what. The car continued to run without a problem so I continued to my destination. When I went back out to the car to go home it was dead as a door nail. I could also smell a "vinegar like odor" in the **** pit. At this point I realized my battery had exploded. Sure enough I opened the compartment and the top of the battery was blown out and there was battery acid sloshed everywhere. I was able to get it out and cleaned up the compartment and a friend took me to a part store and I got a new battery. Started right up. Noticed that the battery gauge was pegged way over to the right on 40. Obviously the voltage reg in the alternator is bad and overcharging killed the previous battery (generating hydrogen). Got the alternator out and realized it is not the original (72 vintage maybe) so I am on the lookout for the correct alternator (1100833) and build date. Not going to be cheap. Anyway, moral of the story is pay attention to your gauges! I am very lucky this did not end in a devastating car fire!!!
Hi,
Is it possible that the battery in the interior wasn't originally perceived as a danger because the batteries were vented?
Is an exploding battery only possible with a 'sealed' battery?
Regards,
Alan
I'm guessing you have a three wire alternator?
If so then where the two wires are ganged together one of them is a smaller gauge wire. That smaller gauge wire is responsible for telling the voltage regulator in your car how much power is needed from the alternator.
If that wire is not hooked up or broken your alternator will produce maximum power to the battery and your ammeter will reflect that.
So check that wire and it's connection.
Check the alternator with a voltmeter at the positive connection. should see something just over 14 volts. No need to replace an alternator that may be working as it should.
Thanks. All of the wires were connected and intact. The voltage regulator is internal to the alternator. That was introduced in 1969.
I am having the unit tested and the shop I am working with can rebuild it easily enough but I really want to get the correct 1969 part number...
When you put her back together use a voltmeter and make sure the two small wires have around the same voltage as the fat red output wire...as REELAV8R said.
