1981 monospring shim kit
Old Jan 31, 2015 | 12:38 PM
jnywadd's Avatar
jnywadd
Default 1981 monospring shim kit
As I am in the process of taking out the differential, I noticed that the rubber is eroded and what look like two shims are crumbled sandwiched between the monospring. There is nothing wrong with the spring itself, I am just looking for the "kit" to install it again and cannot find it anywhere. Does anyone know where to find it or has a dimension, thickness and order in which these have to be re-installed? I can't see spending 300.00 for the kit with the new spring when there is nothing wrong with this one, thanks for anyone's help!
Old Jan 31, 2015 | 11:04 PM
Gale Banks 80''s Avatar
Gale Banks 80'
You might try VB&P. They won't have the OEM but there products for there Spring set up might work for Yours. Yours is way wider at the ends, but I think they are the same or similar in the center. A phone call to them would probably answer this.
A call to Van Steel would also probably produce an answer as well.
Old Feb 1, 2015 | 08:52 AM
jnywadd's Avatar
jnywadd
I will give them a try, thanks for your help!
To 1981 monospring shim kit
