Frame off question.
front to back support on all mounts and the front nose.
attempting to suspend/store above is not a good plan.
Not to mention you will not be able to do any work on the body, while suspended in the air.
I would suggest build a body dolly on wheels on the ground, and store somewhere.
Don't give up so quickly if you want to begin the restoration.
I did my restoration in a 14' wide low ceiling garage.
I built a wooden dolly to sit the body on supported on the underbody. It's a coupe and there was no further support. It sat that way for about 6 years.
I made it as tall as I could with out having the roof hit the ceiling.
I pushed it tight to one side wall. I then did the chassis and running gear restoration next to it.
I moved the body backward and forward as I needed to and did the same with the chassis.
It took a little planning but it all went smoothly.
Here are a couple of pictures to give you an idea.
Regards,
Alan
The body and chassis are pushed to the end of the garage with a door in it and I'm working in front of both of them.
You can just get a hint of the dolly and the body with a cover on it.
Here I have them both pushed forward and I'm working behind them.
If the front clip is securely bonded in place it helps.
I took as much weight out of the front of the body as possible. I did leave the core support in place though.
If you wanted you could run a brace from the core support to the bottom rail of the dolly for extra stability.
I did spend time moving things around as I worked and it did take some planning.
At least this scheme is something to consider.
Regards,
Alan
The body was up high enough to allow easy access to the underside including the rocker channels. Very easy to work on the engine compartment.
The chassis was kept under the body, rolled out to work on. I also had only one bay to work with.
