Transmission Slipping
There are charts for the amount of pressure your transmission should be putting out in different gears while idling and cruising.
It is possible the transmission filter SEAL is not seated properly or is missing completely or there are two seals stuck in the valve body where the filter plugs into which are causing the pump to suck air.
If your transmission has an electrical connector on the case, sometimes the terminals can get corroded or oil-soaked.
If it has a T.V.cable and valve, the cable can get out of adjustment or the valve can get "trash" in it.
The governor could have a bad spring/stripped gear/etc.
All the above problems can be corrected by you and are low-cost repairs/just time consuming though..
If the main valve body is worn/has debris in it.....that is a different story and a last resort because it involves removing the body.
Keep in mind I am only a rookie and have run into these problems......the elimination process was a learning experience!
