Tires before or after alignment?
Old Mar 12, 2015 | 08:51 PM
lionelhutz's Avatar
lionelhutz
So he doesn't know how? Can't explain it? Sorry, but that sounds like an excuse for not knowing.
I've read wheel alignments don't fix funny wear on tires. I have even experienced this with vehicles I have purchased where the alignment didn't fix the bad tire wear, but the new tires were just fine and didn't wear funny in any way.
Old Mar 12, 2015 | 09:10 PM
Priya's Avatar
Priya
He spends all day working on cars, the last thing he wants to do when he gets home is spend his spare time explaining minutia of automotive repair with unknowledgeable people just looking to argue.
And I never said a wheel alignment would fix tires that are already badly worn.
Old Mar 12, 2015 | 09:31 PM
lionelhutz's Avatar
lionelhutz
Don't expect anyone to believe you if you can't explain why. Just brushing off people with the excuse they are unknowledgeable is simply being ignorant and judgmental. Attacking the other people personally is the stupid crap someone does when they don't have an technical explanation. School yard BS - "I'm right and you smell."
Old Mar 13, 2015 | 07:10 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
As much as I don't like to get involved in personal attacks on people, "lionelhutz', I have to agree with you 100%. The tread depth of a brand new tire, is around 1/2". In order to see any "uneven wear", you'd need to change that depth by at least 0.015-0.025".
Therefore, at least IMHO, there's no way in hell, an alignment rack is going to be able to differentiate between that small a change in the tire's dimensions....
Just my $0.02 worth.....
Old Mar 13, 2015 | 07:29 AM
lionelhutz's Avatar
lionelhutz
LOL, well when I get told that's the way it is and you're to unknowledgeable to be capable of understanding why, I take it as nothing more than a very insulting cop-out.
Hell, I aligned my Impala in my garage close enough that when it got on the rack it only required the caster of 1 wheel to be adjusted about 1* to get it perfect. And I used a string and a level while the car was sitting on jack stands under the suspension. Alignments certainly aren't rocket science.
Old Mar 13, 2015 | 12:41 PM
leadfoot4's Avatar
leadfoot4
........ Alignments certainly aren't rocket science.
And with today's alignment technology, not only can you get a more accurate alignment, the software even tells you how to do it!!
I'm old enough to remember when alignments were done on "drive over pits", where the car was driven on to a couple of ramps, that were hung over an open pit, that allowed access to the bottom of the car. Then the mechanic would hang a fixture with a couple of prisms on the front wheels, and do his best to adjust the wheels by a thin column of light, projected on to a scale that was mounted on the wall of the shop, at the front end of the pit......And the adjustments were at best, a close "guesstimate", depending on the vision on the mechanic.
