Power Steering BBC Swap
Old Mar 13, 2015 | 10:57 AM
DO2G's Avatar
DO2G
Default Power Steering BBC Swap
Can the brackets and all power steering components be used from a SBC to a BBC?
Old Mar 13, 2015 | 11:31 AM
MelWff's Avatar
MelWff
Depends on which parts you are referring to. Something like the bracket that mounts the pump to the block is different but most of the rest is the same. You can check any vendor site to see if a particular part is listed as SB or BB or both.
Old Mar 13, 2015 | 12:15 PM
DO2G's Avatar
DO2G
thank you
Old Mar 13, 2015 | 03:48 PM
Condo_454C3's Avatar
Condo_454C3
Depending on your set up, the pulley is different, the upper bracket is different and 1 of the lines is different.
Old Mar 14, 2015 | 12:23 PM
scrappy76's Avatar
scrappy76
I am pretty sure you will have a hard time lining up the pulleys. Only way to tell is try it and see what happens. Make sure you try a belt and see if if its aligned. If you are a little off, you will throw belts at higher rpms.
To Power Steering BBC Swap
