Trip Odometer cable.
Old Apr 4, 2015 | 08:06 PM
Roadster71's Avatar
Roadster71
Default Trip Odometer cable.
Anybody know how to route this cable and miss the support brackets for the steering wheel? Regardless of how I do it the bend is to tight and binds the cable. The car is a 71 convertible.
Old Apr 4, 2015 | 08:21 PM
oldchev's Avatar
oldchev
Sorry I don't have an answer for you. Just empathy, mine is the same way. Dave.
Old Apr 4, 2015 | 08:27 PM
GUSTO14's Avatar
GUSTO14
I believe many folks route and connect the cable with the cluster pulled out for easier access. Then they slide the cluster in and the cable pushes against the brace. This of course causes the cable to bind and in my case it actually bent the speedometer head. I discovered this after having a frame-off completed on my '73 convertible.
My tripometer would not work (it had worked prior to the frame-off) so I removed the cluster to investigate only to discover the kinked cable and damaged speedometer head. I purchased a new speedometer head and then carefully examined how best to avoid kinking the cable. In my case I determined that feeding the cable over the brace with the cluster in place and then routing it down to the bracket worked just fine. No kink and long enough to reach both destinations.
Good luck... GUSTO
Old Apr 5, 2015 | 08:25 AM
Roadster71's Avatar
Roadster71
Good luck... GUSTO
Thanks. you have to wonder how it was ever done on a production line?
Old Apr 5, 2015 | 10:28 AM
Alan 71's Avatar
Alan 71
Hi,
Here's a couple of pictures of the cable and it's bracket in their typical installation.
Perhaps it will help
Regards,
Alan
Old Apr 5, 2015 | 10:52 AM
Roadster71's Avatar
Roadster71
Originally Posted by Alan 71
Hi,
Regards,
Alan
Thanks Alan. That's the way I had it but it bumps into the bracing for the steering column.
Old Apr 5, 2015 | 11:44 AM
Alan 71's Avatar
Alan 71
Hi R,
Is the brace it bumps one of the braces added to convertible cowls?
If so it would be a help to hear from a convertible owner.
Regards,
Alan
Old Apr 6, 2015 | 08:45 AM
Roadster71's Avatar
Roadster71
Hi R,
Regards,
Alan
That's the one
Old Apr 6, 2015 | 08:59 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Well.....that explains why my reset cable works perfectly.
The previous owner removed the brace....I'll make one that has a bend to allow for the reset cable. The only good thing about not having a complete car is "being able to improve on the GM design so that things fit/work correctly"....LOL.
Can someone post a pic of the original brace in place/thanks.
Old Apr 6, 2015 | 10:13 AM
DSchaefe's Avatar
DSchaefe
I managed to get mine working, bought a new cable and dropped the column and pulled the gauge cluster back for access, didn't take any pictures but it was not terribly painful with everything pulled apart. I'd say pull it all apart and then try...
Old Apr 6, 2015 | 10:29 AM
Roadster71's Avatar
Roadster71
Here's a picture. Cable and odometer connection lines up with the lower leg of the bracket and forces a tight bend.
Old Apr 6, 2015 | 11:43 PM
LRB's Avatar
LRB
Hi R,
Regards,
Alan
My 75 convertible did not have all the braces when I took it apart so I found the missing brace on line and added it. It made it so tough getting that cable correctly placed as well as getting the speedometer cable back on. I got the dash all back together and speedometer works, but odometer cable is crimped and will not turn. Leaving it for now.
Old Apr 7, 2015 | 08:12 AM
Roadster71's Avatar
Roadster71
I going to do the same thing. Spent to much time on it already. Every time the dash gets pulled an reinstalled you take another chance of something else going wrong.
Old Apr 7, 2015 | 10:14 AM
Alan 71's Avatar
Alan 71
Hi R71,
Until I saw your picture I thought you were asking about the trip odometer reset cable/**** not the speedometer cable. (that's what my pictures show). Which are you asking about?
Are you sure the speedometer cable is coming through the proper grommet in the firewall and is the correct length?
The AIM shows a clip that holds the cable tight to the steering column… is there one on your car?
Regards,
Alan
Old Apr 7, 2015 | 05:23 PM
Roadster71's Avatar
Roadster71
Hi R71,
Regards,
Alan
The trip odometer cable is the problem. Speedo is fine. Picture was just to show the bracing.
To Trip Odometer cable.
