What is this part called and how to replace
Not sure what they would call it on your year but on my 69 that would be similar to a seat belt mounting bracket.
Took a quick look around and dont really see them anywhere. Doesn't look to hard to make up on your own.... looks like you'll have to cut it off the rocker channel and the floor to make up your own.
My suggestion on this and your #2 mount post.... clean up the areas ... remove as much weak stuff as possible then make up a small patch and weld it into place and coat it with something... the repair will outlive us all. Keep it outa the road salt..
If these guys dont make them ... then most likely no one does.....
http://www.vetteproducts.net/
Received 1,469 Likes
Cruise-In II Veteran
Do you have the 75 AIM? Could be pockets for the seat belt retactors to mount.
This is the only reference I saw in the AIM.
Received 2,878 Likes
Hi MMVLF,
Maybe?!? Can't tell for sure from the picture.
Try CSC Reproduction Corvette Parts.
B4082L and B4082R
440-331-8939
Regards,
Alan
B4082L and B4082R
440-331-8939
Regards,
Alan
Thanks for the reply Alan.
The part number B4082LR is shown in the image below and is not the part I'm looking for. The part I'm trying to identify and replace is the "T" shaped metal bracket that is beside it. It's close to the "2" in the AIM photo.
looking at the pictures, I fail to see the reason you are trying to replace them. If the holes are stripped repair them or go to the next size bolt.
The issue has nothing to do with any stripped threads, as I could have removed the nuts and tig welded in new ones if that was the problem. To me that's a simple problem.
