lowering my '76 vette
Old Aug 20, 2002 | 08:06 AM
aussie_vette_stingray's Avatar
4th Gear
Default lowering my '76 vette
anyone know of who sells lowering kits for the c3 vettes??? i wanna lower front and rear by at least an inch or so.. on front i have like normal coil suspension. the rear i replaced with a hearvier sway bar and composite spring :) .. any help appreciated all :cheers: :flag
Old Aug 20, 2002 | 08:25 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: lowering my '76 vette (aussie_vette_stingray)
Inexpensive route to lower front suspension would be to cut one coil from the bottom of the coil. Use a sut off wheel on a drill or air grinder. Don't use a torch. That should lower the front end 1-1.5inches. If you screw the coil up and cut too much, you can get TRW replacements from Advance Auto for $48/pr.
Some guys are claiming that VBP 550 springs will lower the front end 1 inch too.
The rear end is lowered using 10 inch spring bolts and loosening the bolt to desired height.
