Oil dipstick tube removal, Goodwrench crate.
Just checking, is the dipstick tube on the Goodwrench engine an interference fit? Wondering if I can simply pull it out. If not, any tips?
When replacing is it a tap fit using small hammer and block of wood?
TIA.
TIA.
Cruise-In IX Veteran
Depending on the style of engine it is probably a little different than what the car originally had. The zz4 engine have the dipstick pressed in, but they also have a retaining bolt. You will need to check for the bolt and if you have one remove it. Then you can just pull it out.
Some here (bolt, wiggle 'n pull) and reinstall was press fit, didn't need a hammer at all (which is pretty surprising for a C3 )
